tranny woes |
tranny woes |
injunmort |
Jun 21 2014, 04:29 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
my '71 w/tailshifter started to pop out of first gear occasionally, now it wont stay in at all. no problems with the other gears and reverse. fairly new shifter bushings and clutch has been adjusted. any thoughts? thank you
Dr Evil |
Jul 19 2014, 03:10 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Tail shifters are the biggest PITA and for lower performance.
You must make sure the shifter rod in the box that is actuated by the tail cone stuff is not dislocated. Then, you must make sure the mechanism in the tail cone is lines up and engaged with that rod. If you dislodged the internal main shift rod, you need to relocated it first and foremost. Hard to explain, a PITA to do. Sorry. Wish you lived closer as it would take me a second. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:24 AM |
