what is this, weep hole? |
jacksun |
Jul 21 2014, 07:48 AM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
hi,
I am wondering what the circled item is? when repairing the hell hole I have used "picklex" to convert the rust inside the longs,(minimal from what I can see) using a spray gun with an attachment hose that I purchased from a company online that sells a different product called "fluid film", a lanolin product. anyway,,, when I sprayed the rust converter with the spraygun/hose, some of the product dripped out of these holes that are original... are these holes, about five per side, meant to allow water to escape from the longs? also, it would seem that water could make it's way UP into the longs as well. thinking of caulking them? forgot the pic oops thanks randal |
bdstone914 |
Jul 22 2014, 07:20 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The longs are not air and water tight. They also added drain holes to the trailing arms. I have seen early trailing arms with no drain holes. Had them dip stripped and they came back with liquid inside. Heating and cooling of metal can cause condensation of moisture of the metal surface.
Lo-Fi Version | Time is now: 10th June 2024 - 10:49 AM |
