Throwout bearing Guide Tube, How do you know if it needs replacing? |
mack914 |
Aug 16 2004, 08:48 PM
Member Group: Members Posts: 387 Joined: 5-July 04 From: Toledo, Oh Member No.: 2,306 |
Throwout bearing is a little sloppy on the guide tube of the replacement trans that I just bought. Is the fact that there is play a reason to replace the guide tube? I will be installing a new throwout bearing. What about the guide tube?
Other ? Can I use the clutch cable that is in my 914 for the 6 conversion that I'm doing? Parts #s indicate that the clutch cable is different for the 914-6. Thanks (IMG:style_emoticons/default/boldblue.gif) |
jdlamonica |
Aug 16 2004, 09:01 PM
Newbie Group: Members Posts: 8 Joined: 16-August 04 From: Pioneertown, Ca. Member No.: 2,542 |
Regarding the throw-out bearing guide tube.
Yes I would replace it. I just replaced the clutch in my 914-6. I put in a new tube but forgot to put grease on the tube for the T.O. bearing to ride on. The T.O. bearing jammed on the tube and the clutch was stuck. The only way I was able to fix the problem was to spray white grease through a tube, through the small access hole at the top of the bell housing on to the T.O. bearing tube. Otherwise I would of had to remove the transmission. It works fine now, but the tube and proper grease are very important for a smooth clutch operation. (IMG:style_emoticons/default/monkeydance.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 04:42 AM |
