rear suspension woes, maxed out camber problem |
kresdon999 |
Jul 23 2014, 08:07 AM
Newbie Group: Members Posts: 14 Joined: 7-February 13 From: Wheeling, WV Member No.: 15,492 Region Association: MidAtlantic Region |
I have a nice dry 72 that was converted to a 2.2 sixer. The car was previously someone's idea of a track day car, and overall is pretty well done. However the rear camber was maxed out so (too big and wide) tires didn't rub the fenders, which were also rolled for clearance. I wanted to return the suspension to more street able specs, but discovered the left camber plate bolts were broken/ missing and stacks of washers were ABOVE the arm while all camber shims were removed/missing. Conversely, the right camber plates had been removed but the bolts were all there and NO washer stacks. I purchased camber shims, but am now confused and perplexed. Any guidance, help, even insightful insults, would be appreciated.
ChrisFoley |
Jul 23 2014, 11:21 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
It sounds to me like someone broke the bolts on the driver side while trying to remove them, then drilled them out badly and had to use thru bolts.
The washers are there to make up for the extra long bolts they decided to use. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:05 AM |
