Which dizzy for carbs? |
rick 918-S |
Jul 26 2014, 06:46 PM
Hey nice rack! -Celette Group: Members Posts: 20,493 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
2.0 with 40's. Which dizzy works best. I need the F.I. one for another engine so I need a replacement. .09? .050? and why?
bdstone914 |
Jul 26 2014, 07:33 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I was told to use an FI distributor and only hook up the vacuum advance. It's a 1.7 with 40 Kadrons. Just getting it dialed in but seems to work ok. I think I still have some more complete ones if that turns out to be a good choice for you.
rick 918-S |
Jul 26 2014, 10:17 PM
I was told to use an FI distributor and only hook up the vacuum advance. It's a 1.7 with 40 Kadrons. Just getting it dialed in but seems to work ok. I think I still have some more complete ones if that turns out to be a good choice for you. It's my understanding that you don't have ported vacuum with webers so the vacuum advance is NFG. So the key as I understand is to get a dizzy with an optimal mechanical advance. So if I'm correct in my understanding I'm wonder who has experience with mechanical advance dizzies and which one is the best baseline choice. |
JFJ914 |
Jul 27 2014, 07:42 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
It's my understanding that you don't have ported vacuum with webers so the vacuum advance is NFG. So the key as I understand is to get a dizzy with an optimal mechanical advance. So if I'm correct in my understanding I'm wonder who has experience with mechanical advance dizzies and which one is the best baseline choice. Most Weber 40's have a vacuum port, it's next to the aux air adj with a small screw in it. Make a tube and connect it up. |
rick 918-S |
Jul 27 2014, 08:09 AM
It's my understanding that you don't have ported vacuum with webers so the vacuum advance is NFG. So the key as I understand is to get a dizzy with an optimal mechanical advance. So if I'm correct in my understanding I'm wonder who has experience with mechanical advance dizzies and which one is the best baseline choice. Most Weber 40's have a vacuum port, it's next to the aux air adj with a small screw in it. Make a tube and connect it up. Thanks for the info. Is it ported vacuum? If it's direct intake vacuum it will just pull the advance in and hold it. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:54 AM |
