Compression question, What should I do? |
monkeyboy |
Jul 27 2014, 01:21 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I pulled my motor out of the car to work on my Fuel Injection project.
When I pulled the motor I did a compression test. Cylinder 3 and 4 are at 115-120 PSI, and 1 and 2 are at 130 PSI. Is that difference anything to worry about? Leakdown is only 2-3 % on any cylinder. Should I yank the heads and check the deck height since I have it apart, or is this not enough to worry about on a stock 2.0? |
euro911 |
Jul 27 2014, 02:42 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
If you have the motor out and partially disassembled, half the battle is over.
If you have the time and a little play $, pull the heads and barrels, inspect the cylinder bores and check your rod play. If the cam and lifters (and cam bearings) are OK too, you can re-ring it and lap the valves and seats (although your leak-down #s look ok). 15 #s is low though … it's only 8.5% of your highest compression reading (130 psi). I'd pump more in there to obtain a more accurate reading. You've got a little homework to do. EDIT: I think I misunderstood - were you referring to the 130 vs 115?, or using 15 # to check your leak down? 130 is 13% higher than 115 and you'd like to keep lower than 10% difference |
Lo-Fi Version | Time is now: 8th June 2024 - 04:22 PM |
