> I think my clutch exploded, Edit...actually a rear axle split in half
era vulgaris
post Jul 29 2014, 04:35 PM
J is for Genius
So I was running up to the store to drop off some Red Box movies, and pulling away from a stop sign I heard a loud pop....then the car stopped moving. The engine was still running and idling fine, but when I put it into 1st again and tried to pull away, the car didn't move and I could hear a sound like rocks in a rock tumbler. I'm guessing clutch pieces rattling around the bell housing?
I tried just shifting through the gears while stopped and I could find every gear fine, so I'm hoping it's nothing internal to the trans.
Luckily this happened just a few hundred yards from my house in my neighborhood so getting it back to my house was easy. I'm going to have it towed to a local aircooled shop. But does this sound like a clutch disc that shattered, or possibly something more serious?
Of course this had to happen just after I sold my Karmann Ghia, so I have no other means of transport except to borrow my girlfriend's car!
era vulgaris
post Jul 30 2014, 12:17 PM
J is for Genius
Are the stub axles not interchangeable between 914 and 911?
So if, for example, I ordered that axle assembly pictured above from Tangerine, would I need to buy it with the stub axle?
So this is my other axle, which doesn't have a weld like the one that broke. Does this also have 911 CV's? What are the visual clues to differentiate between 914 and 911 CV's and stub axles?
Sorry for all the questions, this is new territory for me!
era vulgaris   I think my clutch exploded   Jul 29 2014, 04:35 PM
Old Yella   Check the cv joints first. So I was running up ...   Jul 29 2014, 04:42 PM
Dave_Darling   CV joint broke, or (more likely) unbolted itself f...   Jul 29 2014, 04:44 PM
Cap'n Krusty   Right. If you can get it into all the gears with ...   Jul 29 2014, 04:44 PM
dlee6204   :agree:   Jul 29 2014, 04:48 PM
era vulgaris   Thanks guys, I'll check and see if that's ...   Jul 29 2014, 04:56 PM
flippa   :agree: Been there, done that.   Jul 29 2014, 05:29 PM
era vulgaris   Well, the CV joints might still be an issue...but ...   Jul 29 2014, 05:48 PM
JRust   Those do look like the thicker 911 cv's. Not s...   Jul 29 2014, 06:07 PM
era vulgaris   Those do look like the thicker 911 cv's. Not ...   Jul 30 2014, 08:06 PM
bdstone914   Those do look like the thicker 911 cv's. Not...   Jul 30 2014, 11:00 PM
JawjaPorsche   Contact Chris at Tangerine Racing for your new axl...   Jul 29 2014, 06:15 PM
bdstone914   You probably should pull the outer CV aand stub ax...   Jul 29 2014, 06:26 PM
era vulgaris   Are the stub axles not interchangeable between 914...   Jul 30 2014, 12:17 PM
bdstone914   Are the stub axles not interchangeable between 91...   Jul 30 2014, 01:55 PM
bdstone914   [You should also run the wires to the back up ligh...   Jul 30 2014, 01:59 PM
bdstone914   Now that I look closer you have a spacer between t...   Jul 30 2014, 02:03 PM
era vulgaris   Also, it's been a while since I had the rear w...   Jul 30 2014, 12:39 PM
Krieger   That is a custom POS axle. It looks like it was c...   Jul 30 2014, 02:28 PM
Andyrew   That is a custom POS axle. It looks like it was ...   Jul 30 2014, 03:13 PM
Old Yella   Just get two new complete axles with cv's and ...   Jul 30 2014, 02:28 PM
Racer Chris   The person who thought it was a good idea to weld ...   Jul 30 2014, 03:34 PM
era vulgaris   Shit, what a nightmare. The output flanges on the...   Jul 30 2014, 07:34 PM
Mike Bellis   Take it off, measure the length and spline count. ...   Jul 30 2014, 09:52 PM
bdstone914   If you do pull the axle and stub axle do not roll ...   Jul 30 2014, 11:09 PM
era vulgaris   Bruce, if it hasn't been said, you are the man...   Jul 30 2014, 11:19 PM
era vulgaris   So I managed to get the trans side of the axle off...   Jul 31 2014, 07:43 PM
ThePaintedMan   1 1/16" is the largest I've got, what si...   Jul 31 2014, 08:06 PM
Mike Bellis   Use the axle like a slide hammer to get it off.   Jul 31 2014, 08:41 PM
era vulgaris   Use the axle like a slide hammer to get it off. ...   Jul 31 2014, 08:57 PM
Eric_Shea   Just buy a pair of free floating Sway-A-Way axles....   Jul 31 2014, 08:46 PM
era vulgaris   Just buy a pair of free floating Sway-A-Way axles...   Jul 31 2014, 08:56 PM
Eric_Shea   You will. You can crack the cage. Best to take it ...   Jul 31 2014, 09:30 PM
Mike Bellis   These are chrome moly and cheaper... This is what ...   Jul 31 2014, 09:33 PM
Eric_Shea   These are chrome moly and cheaper... This is what...   Jul 31 2014, 09:36 PM
Eric_Shea   Sorry, are you talking about getting the stub axle...   Jul 31 2014, 09:34 PM
era vulgaris   Sorry, are you talking about getting the stub axl...   Jul 31 2014, 09:52 PM
Mike Bellis   You're stuck on the dowel pins. You can use a ...   Jul 31 2014, 09:54 PM
Eric_Shea   Put a screwdriver on the "gasket" by the...   Jul 31 2014, 10:03 PM
era vulgaris   Thanks guys! I'll give it a try in the mo...   Jul 31 2014, 10:07 PM
bdstone914   I don't think you can get a screw driver down ...   Aug 1 2014, 07:13 AM
Mike Bellis   get the screwdriver next to the CV and try to wigg...   Aug 1 2014, 10:17 AM
Dr Evil   Did you still need a set of stock 914 output flang...   Aug 3 2014, 06:16 PM
era vulgaris   Did you still need a set of stock 914 output flan...   Aug 4 2014, 11:13 AM
era vulgaris   So is there any way to get a new axle assembly in ...   Aug 7 2014, 07:32 PM
bdstone914   So is there any way to get a new axle assembly in...   Aug 7 2014, 07:55 PM
era vulgaris   You can get them in with out removing the heat e...   Aug 7 2014, 08:24 PM
76-914   So is there any way to get a new axle assembly in...   Aug 7 2014, 08:02 PM
era vulgaris   I'd start soaking those studs/nuts in PB Bla...   Aug 7 2014, 08:28 PM
Racer Chris   Raise the back end of the car. With the car jacked...   Aug 8 2014, 12:39 AM
era vulgaris   Raise the back end of the car. With the car jacke...   Aug 8 2014, 07:01 AM
Mike Bellis   Raise the back end of the car. With the car jack...   Aug 8 2014, 07:38 AM
era vulgaris   Got it in! So these chromoly axles don't ...   Aug 8 2014, 10:31 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:45 PM
