| era vulgaris |
Jul 29 2014, 04:35 PM
J is for Genius ![]() ![]() ![]() Group: Members Posts: 986 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
So I was running up to the store to drop off some Red Box movies, and pulling away from a stop sign I heard a loud pop....then the car stopped moving. The engine was still running and idling fine, but when I put it into 1st again and tried to pull away, the car didn't move and I could hear a sound like rocks in a rock tumbler. I'm guessing clutch pieces rattling around the bell housing?
I tried just shifting through the gears while stopped and I could find every gear fine, so I'm hoping it's nothing internal to the trans. Luckily this happened just a few hundred yards from my house in my neighborhood so getting it back to my house was easy. I'm going to have it towed to a local aircooled shop. But does this sound like a clutch disc that shattered, or possibly something more serious? Of course this had to happen just after I sold my Karmann Ghia, so I have no other means of transport except to borrow my girlfriend's car! |
| Krieger |
Jul 30 2014, 02:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,847 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
That is a custom POS axle. It looks like it was cut and then spaced to be longer with a tube welded on the ends.
| Andyrew |
Jul 30 2014, 03:13 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
era vulgaris I think my clutch exploded Jul 29 2014, 04:35 PM
Old Yella Check the cv joints first.
So I was running up ... Jul 29 2014, 04:42 PM
Dave_Darling CV joint broke, or (more likely) unbolted itself f... Jul 29 2014, 04:44 PM
Cap'n Krusty Right. If you can get it into all the gears with ... Jul 29 2014, 04:44 PM
dlee6204 :agree: Jul 29 2014, 04:48 PM
era vulgaris Thanks guys, I'll check and see if that's ... Jul 29 2014, 04:56 PM
flippa :agree:
Been there, done that. Jul 29 2014, 05:29 PM
era vulgaris Well, the CV joints might still be an issue...but ... Jul 29 2014, 05:48 PM
JRust Those do look like the thicker 911 cv's. Not s... Jul 29 2014, 06:07 PM
era vulgaris
Those do look like the thicker 911 cv's. Not ... Jul 30 2014, 08:06 PM
bdstone914
Those do look like the thicker 911 cv's. Not... Jul 30 2014, 11:00 PM
JawjaPorsche Contact Chris at Tangerine Racing for your new axl... Jul 29 2014, 06:15 PM
bdstone914 You probably should pull the outer CV aand stub ax... Jul 29 2014, 06:26 PM
era vulgaris Are the stub axles not interchangeable between 914... Jul 30 2014, 12:17 PM
bdstone914
Are the stub axles not interchangeable between 91... Jul 30 2014, 01:55 PM
bdstone914 [You should also run the wires to the back up ligh... Jul 30 2014, 01:59 PM
bdstone914 Now that I look closer you have a spacer between t... Jul 30 2014, 02:03 PM
era vulgaris Also, it's been a while since I had the rear w... Jul 30 2014, 12:39 PM
Old Yella Just get two new complete axles with cv's and ... Jul 30 2014, 02:28 PM
Racer Chris The person who thought it was a good idea to weld ... Jul 30 2014, 03:34 PM
era vulgaris Shit, what a nightmare. The output flanges on the... Jul 30 2014, 07:34 PM
Mike Bellis Take it off, measure the length and spline count. ... Jul 30 2014, 09:52 PM
bdstone914 If you do pull the axle and stub axle do not roll ... Jul 30 2014, 11:09 PM
era vulgaris Bruce, if it hasn't been said, you are the man... Jul 30 2014, 11:19 PM
era vulgaris So I managed to get the trans side of the axle off... Jul 31 2014, 07:43 PM
ThePaintedMan
1 1/16" is the largest I've got, what si... Jul 31 2014, 08:06 PM
Mike Bellis Use the axle like a slide hammer to get it off. Jul 31 2014, 08:41 PM
era vulgaris
... Jul 31 2014, 08:57 PM
Eric_Shea Just buy a pair of free floating Sway-A-Way axles.... Jul 31 2014, 08:46 PM
era vulgaris
Just buy a pair of free floating Sway-A-Way axles... Jul 31 2014, 08:56 PM
Eric_Shea You will. You can crack the cage. Best to take it ... Jul 31 2014, 09:30 PM
Mike Bellis These are chrome moly and cheaper... This is what ... Jul 31 2014, 09:33 PM
Eric_Shea
These are chrome moly and cheaper... This is what... Jul 31 2014, 09:36 PM
Eric_Shea Sorry, are you talking about getting the stub axle... Jul 31 2014, 09:34 PM
era vulgaris
Sorry, are you talking about getting the stub axl... Jul 31 2014, 09:52 PM
Mike Bellis You're stuck on the dowel pins. You can use a ... Jul 31 2014, 09:54 PM
Eric_Shea Put a screwdriver on the "gasket" by the... Jul 31 2014, 10:03 PM
era vulgaris Thanks guys! I'll give it a try in the mo... Jul 31 2014, 10:07 PM
bdstone914 I don't think you can get a screw driver down ... Aug 1 2014, 07:13 AM
Mike Bellis get the screwdriver next to the CV and try to wigg... Aug 1 2014, 10:17 AM
Dr Evil Did you still need a set of stock 914 output flang... Aug 3 2014, 06:16 PM
era vulgaris
Did you still need a set of stock 914 output flan... Aug 4 2014, 11:13 AM
era vulgaris So is there any way to get a new axle assembly in ... Aug 7 2014, 07:32 PM
bdstone914
So is there any way to get a new axle assembly in... Aug 7 2014, 07:55 PM
era vulgaris
You can get them in with out removing the heat e... Aug 7 2014, 08:24 PM
76-914
So is there any way to get a new axle assembly in... Aug 7 2014, 08:02 PM
era vulgaris
I'd start soaking those studs/nuts in PB Bla... Aug 7 2014, 08:28 PM
Racer Chris Raise the back end of the car.
With the car jacked... Aug 8 2014, 12:39 AM
era vulgaris
With the car jacke... Aug 8 2014, 07:01 AM
Mike Bellis
With the car jack... Aug 8 2014, 07:38 AM
era vulgaris Got it in! So these chromoly axles don't ... Aug 8 2014, 10:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:12 PM |
