Fuel pressure builds after a short while |
Seabird |
Aug 4 2014, 08:41 AM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
Hello all!
Having some on going difficulties with my fuel system. Last time at the track I had a lean running condition when under load on the 1-2 bank. Swapped a gasket once back home and now can't replicate the problem. Decided I was going to refresh a few components as a precautionary measure. Fuel regulator (as this is where the split happens between the left and right carbs), fuel pressure gauge (the old one was well old), and adding a spare carb to my track side spares. Previously I had not had a problem with fuel pressure per the gauge. After swapping in a fresh Holley 12-804 and an oil filled gauge I was unable to regulate the pressure down to 3 psi. Was not able to regulated it lower than 15 psi for that matter. A little research on the web indicated that the 12-804 and the higher pressure 12-803 sometimes get mislabeled. So I bought a rebuild kit which came with both springs. Swapped the new low pressure spring into the new regulator. Initially I could get the pressure in the 3 lb range but after a sort while the pressure would creep up. To make matters worse if I bounce the throttle I actually can watch the fuel pressure drop off (IMG:style_emoticons/default/hissyfit.gif) The fuel pump is a Holley blue top so it has a max pressure of 14 psi. My next track day is 2 Saturdays from now so I need to sort this soon. Has anyone else run across this before? Thanks, Miguel |
ThePaintedMan |
Aug 4 2014, 09:27 AM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Miguel,
The simpler (and probably simpler) way to go about this would be to just put a self-regulated Carter-style pump in. The ones CB Performance sells are well known for their reliability and match well with just about any dual carb setup. http://www.cbperformance.com/ProductDetail...roductCode=3193 If nothing else, you could order one as your spare and if you have trouble at the track day, this would be simple to install at the track. |
Lo-Fi Version | Time is now: 8th June 2024 - 08:31 AM |
