moving fuel pump to front, fuel pump |
hndyhrr |
Aug 4 2014, 09:51 AM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
Pumpkin is a 1970 4 cyc. I am planning on moving the pump to the front of car. I have replaced the fuel lines thru the tunnel with stainless steel lines. So here are a couple of questions i have.
In the tech article about this it says something about a blister bracket (?) where do i get this. do i need to replace the plastic lines from the firewall to the engine compartment? I found that tangarine has the fuel line that is bigger on one end and smaller on other for the fuel pump, good idea to get this one? I thought at one point in time AA has a kit but i will not go there. anyone else sell this kit? Any thoughts, hints or don't do it ths way suggestions will be greatly appreciated. Thanks in advance Renee (IMG:style_emoticons/default/driving-girl.gif) |
SLITS |
Aug 4 2014, 10:30 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Pumpkin is a 1970 4 cyc. I am planning on moving the pump to the front of car. I have replaced the fuel lines thru the tunnel with stainless steel lines. So here are a couple of questions i have. In the tech article about this it says something about a blister bracket (?) where do i get this.'75 - '76 914 do i need to replace the plastic lines from the firewall to the engine compartment?If you are talking about the ones that run from the fuel pump/filter up throuht the engine shelf ... they are made by Robert I found that tangarine has the fuel line that is bigger on one end and smaller on other for the fuel pump, good idea to get this one?Depends on if you use the stock filter I thought at one point in time AA has a kit but i will not go there. anyone else sell this kit?You can purchase the hose & clamps most anywhere Any thoughts, hints or don't do it ths way suggestions will be greatly appreciated. Thanks in advance Renee (IMG:style_emoticons/default/driving-girl.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 03:45 AM |
