Fuel pressure builds after a short while |
Seabird |
Aug 4 2014, 08:41 AM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
Hello all!
Having some on going difficulties with my fuel system. Last time at the track I had a lean running condition when under load on the 1-2 bank. Swapped a gasket once back home and now can't replicate the problem. Decided I was going to refresh a few components as a precautionary measure. Fuel regulator (as this is where the split happens between the left and right carbs), fuel pressure gauge (the old one was well old), and adding a spare carb to my track side spares. Previously I had not had a problem with fuel pressure per the gauge. After swapping in a fresh Holley 12-804 and an oil filled gauge I was unable to regulate the pressure down to 3 psi. Was not able to regulated it lower than 15 psi for that matter. A little research on the web indicated that the 12-804 and the higher pressure 12-803 sometimes get mislabeled. So I bought a rebuild kit which came with both springs. Swapped the new low pressure spring into the new regulator. Initially I could get the pressure in the 3 lb range but after a sort while the pressure would creep up. To make matters worse if I bounce the throttle I actually can watch the fuel pressure drop off (IMG:style_emoticons/default/hissyfit.gif) The fuel pump is a Holley blue top so it has a max pressure of 14 psi. My next track day is 2 Saturdays from now so I need to sort this soon. Has anyone else run across this before? Thanks, Miguel |
stugray |
Aug 4 2014, 02:51 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Just this last weekend (first time on the track) I was having a similar issue.
Car would run great for ~10 minutes hard, then start to bog at WOT and not have the same pep. Hard to tell if it is a lean or rich condition (murphy's law = datalogging was not working when this happened for AFR & EGTs). I suspect a fuel pressure problem. I have the holley red pump & regulator up front with the fuel cell, 3/8" steel line through the tunnel and a pressure gauge at the splitter in the back where they split and go to dual fuel filters & 40 IDFs. I have nice new lines everywhere except from the fuel filters to the carbs. Damn those weber fuel inlets being 5/16" / 8-9mm! I will definitely be replacing the weber inlet hosebarbs with AN fittings...( anyone know the drill & tap size for that?) I am even considering putting in a fuel pressure sensor and logging it with everything else. It is not heat soak as I have the phenolic spacers, tall intakes, and carbs are cool to the touch when I come in. |
ChrisFoley |
Aug 4 2014, 03:47 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I will definitely be replacing the weber inlet hosebarbs with AN fittings...( anyone know the drill & tap size for that?) In the past I've tapped them with 1/8" npt IIRC. More recently I found some fittings with the correct metric thread. I think they're M10 x 1 or something odd like that and I think I got them at Pegasus. |
stownsen914 |
Aug 4 2014, 06:29 PM
Senior Member Group: Members Posts: 916 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
One random thought after reading the thread again. Are you sure you're measuring pressure in the right place? If you measure upstream of the regulator, you will certainly see higher pressure ...
Lo-Fi Version | Time is now: 8th June 2024 - 04:51 PM |
