Socal70 |
Newbie ![]() Group: Members Posts: 4 Joined: 4-August 14 From: Vista, ca Member No.: 17,731 Region Association: None ![]() |
So I just pulled my transmission out of my 70 (side shifter with a 1.8), I replaced my flywheel due to work teeth, got the car back together and the car sounded great for 5 minutes and then developed a light grinding noise. It's coming from the transmission area and most noticeable when it's idling. Anyone had similar issues?
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,735 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Check the starter shaft/gears for scaring. Did you lose the big o-ring between the crank and flywheel when you changed it? Maybe one of the shims is rubbing on it. Pull the flywheel and check for rubbing/clearance issue against the case.
Lo-Fi Version | Time is now: 7th July 2025 - 05:54 AM |
