Turn signal switch, How to statically test? |
HalfMoon |
Aug 4 2014, 09:44 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
How do we statically test (ohn meter or continuity tester) a column turn signal switch un-installed?
TY David |
Mike Bellis |
Aug 4 2014, 10:03 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
3 wires
Black w/green & white stripe (common) Black w/ green stripe Black w/ white stripe Test continuity between the common to one of the other two while the switch is turned. EDIT: you may have to disconnect all three from the circuit to get an accurate reading. |
HalfMoon |
Aug 4 2014, 10:17 PM
3 wires Black w/green & white stripe (common) Black w/ green stripe Black w/ white stripe Test continuity between the common to one of the other two while the switch is turned. EDIT: you may have to disconnect all three from the circuit to get an accurate reading. Great stuff! I have continuity on those pins (IMG:style_emoticons/default/piratenanner.gif) Do you happen to know whitch pin should have continuity when tested against common for the high beam? |
Lo-Fi Version | Time is now: 6th June 2024 - 12:37 PM |
