Fuel pressure builds after a short while |
Seabird |
Aug 4 2014, 08:41 AM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
Hello all!
Having some on going difficulties with my fuel system. Last time at the track I had a lean running condition when under load on the 1-2 bank. Swapped a gasket once back home and now can't replicate the problem. Decided I was going to refresh a few components as a precautionary measure. Fuel regulator (as this is where the split happens between the left and right carbs), fuel pressure gauge (the old one was well old), and adding a spare carb to my track side spares. Previously I had not had a problem with fuel pressure per the gauge. After swapping in a fresh Holley 12-804 and an oil filled gauge I was unable to regulate the pressure down to 3 psi. Was not able to regulated it lower than 15 psi for that matter. A little research on the web indicated that the 12-804 and the higher pressure 12-803 sometimes get mislabeled. So I bought a rebuild kit which came with both springs. Swapped the new low pressure spring into the new regulator. Initially I could get the pressure in the 3 lb range but after a sort while the pressure would creep up. To make matters worse if I bounce the throttle I actually can watch the fuel pressure drop off (IMG:style_emoticons/default/hissyfit.gif) The fuel pump is a Holley blue top so it has a max pressure of 14 psi. My next track day is 2 Saturdays from now so I need to sort this soon. Has anyone else run across this before? Thanks, Miguel |
stugray |
Aug 6 2014, 08:31 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
In the past I've tapped them with 1/8" npt IIRC. More recently I found some fittings with the correct metric thread. I think they're M10 x 1 or something odd like that and I think I got them at Pegasus. Here is the part number form Summit RUS-670480 and a link: -6AN to 10x1 Makes for a super clean install and very serviceable. Miguel Thanks both of you. I looked at the carbs last night without pulling the lines. It looks like the hose barb nipples on the carbs is just pressfit in. Is that correct, or is it actually threaded? I'll order the parts from the link above and I have the taps, but I just wanted to be prepared to do it right. (And sorry for the thread-hijack) |
Lo-Fi Version | Time is now: 8th June 2024 - 01:58 PM |
