Fuch I had a fire! Now repaired, Back together & running. Picking it up next week |
JRust |
Aug 5 2014, 10:10 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I opened my garage tonight to troubleshoot wiring. There was a smokey smell in it pretty strong. No smoke though so I was a little confused. I look in my rear trunk which was open as I was testing ECU wiring the previous night. I did pull one of the 3 relays last night that sit by my ECU. Just wanted to grab some in town to swap out & rule those out as a possible problem. I did not leave the key on or anything. I didn't think to pull the ground. I don't see why I'd need to as all I did was pull a relay. HOW the fuch does this happen just sitting?
I admit I am no genius with wiring but really? How could pulling a relay catch my car on fire? I guess I should feel lucky as this happened in my closed garage with nobody the wiser. It is also just the battery & into my trunk. I sure as hell don't feel lucky. I feel like I got kicked in the nuts repeatedly really hard (IMG:style_emoticons/default/sad.gif) Attached image(s) |
Spoke |
Aug 6 2014, 12:31 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Wow, that sucks.
Good thing it didn't catch other stuff on fire and burn the entire 914 and garage. Looking at the damage, one has to wonder if the battery was shorted, burned, and burned the electronics, or the electronics burned and cause the battery to burn. It would seem that a heavy current drain from the electronics would not cause the battery to burn. The battery should be able to drain 10, 20A without burning up. |
Lo-Fi Version | Time is now: 9th June 2024 - 02:54 PM |
