Transmission issues, trouble finding first and reverse |
Alapone |
Aug 8 2014, 07:34 AM
Member Group: Members Posts: 105 Joined: 4-April 13 From: Nj Member No.: 15,734 Region Association: None |
Hello all,
I have been having difficulty finding first and reverse intermittently on my past few drives. Let me start at the beginning, I bought the car 2 years ago without being able to put it into 4th or 5th gear. Being new to this and really just wanting to get the car on the road, I drove it promptly (and screaming in 3rd) to a mechanic who specialized primarily in older british and newer german/Japanese stuff. He told me I needed to repair the linkage. He did that and the thing shifted like a (914) dream for the next year and change. Four months ago I noticed new (and pretty significant) play in the linkage. I thought it was the mechanic's work coming undone though it seemed pretty soon. I drove it like that for another 3 months because there was no real problem hitting all the gears, it just felt a little sloppy. Two weeks ago after a decent hour and half drive at hwy speeds with no problems and returning home to stop and go traffic, I wasn't able to put the car in first gear. If I double clutched it would slip in with a little bit of protest. Since then it has been spotty acting up at times and other times no problem. Bad synchros? just the linage ? shift tube? worse? I live in the city so I haven't had space to get it up in the air and take a look for myself. Plus Im not well versed enough to take a trans apart and inspect. long winded I know. Any ideas? Thanks for the help |
stugray |
Aug 8 2014, 08:40 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Side shift bushing (trans end):
http://www.ebay.com/sch/sis.html?_nkw=PORS...Id=380631223466 And shift rod bearing (upper right): http://www.tangerineracing.com/transmission.htm Then PP has the shifter bushings that go in the shaft itself (Shift Coupler Bushing Set ): http://www.pelicanparts.com/catalog/SuperC...T_pg2.htm#item4 Replace all of those (or verify that your mechanic did that) and it will be better than new |
Lo-Fi Version | Time is now: 7th June 2024 - 05:15 AM |
