Transmission issues, trouble finding first and reverse |
Alapone |
Aug 8 2014, 07:34 AM
Member Group: Members Posts: 105 Joined: 4-April 13 From: Nj Member No.: 15,734 Region Association: None |
Hello all,
I have been having difficulty finding first and reverse intermittently on my past few drives. Let me start at the beginning, I bought the car 2 years ago without being able to put it into 4th or 5th gear. Being new to this and really just wanting to get the car on the road, I drove it promptly (and screaming in 3rd) to a mechanic who specialized primarily in older british and newer german/Japanese stuff. He told me I needed to repair the linkage. He did that and the thing shifted like a (914) dream for the next year and change. Four months ago I noticed new (and pretty significant) play in the linkage. I thought it was the mechanic's work coming undone though it seemed pretty soon. I drove it like that for another 3 months because there was no real problem hitting all the gears, it just felt a little sloppy. Two weeks ago after a decent hour and half drive at hwy speeds with no problems and returning home to stop and go traffic, I wasn't able to put the car in first gear. If I double clutched it would slip in with a little bit of protest. Since then it has been spotty acting up at times and other times no problem. Bad synchros? just the linage ? shift tube? worse? I live in the city so I haven't had space to get it up in the air and take a look for myself. Plus Im not well versed enough to take a trans apart and inspect. long winded I know. Any ideas? Thanks for the help |
Cap'n Krusty |
Aug 8 2014, 09:24 AM
Just because the bushings are aftermarket doesn't mean they're "suspect". The look and feel just like the ones you might get from Porsche because they probably ARE the ones you get from the dealer, except for the coupler bushings, which are BETTER than the originals because Porsche doesn't even sell them as separate parts (and the OE ones were junk, anyway). (I can't comment on the bushings sold by AA because I have always sourced mine from the same people GPR gets theirs, and I've NEVER had a problem with them.) My first inspection point would be the cone screws, because a lot of people, including professional techs, don't bother to change them. They are a SINGLE USE item! No glue, JB Weld, Loctite, or anything else is necessary. In a pinch, a used one in the coupler is OK if you wrap the coupler in electrical tape to assure the screw doesn't fall out, but it should be replaced at the earliest opportunity. Can't do that in the back.
Good luck! The Cap'n |
Lo-Fi Version | Time is now: 7th June 2024 - 12:28 AM |
