Fuel pump question, Temporary switch to carbs |
JStroud |
Aug 11 2014, 07:59 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Ok I've pulled my 2.7 with CIS to do a rebuild, I've got a 2.7 with carbs I'm installing while my motor is down, trying to make it to RRC.
So my question, can I install the carb fuel pump and just leave my FI pump in place, will the carb pump be able to pull the gas thru the other pump( power disconnected ) or will I have to take it out. Or should I just use the FI pump and install a pressure regulator. The FI pump is in the front trunk(75-76 location) was thinking of just mounting the carb pump on the firewall in the engine compartment. This is just a temporary swap so trying to keep it simple, and easy to change back. Thanks, Jeff |
SLITS |
Aug 11 2014, 01:58 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Disconnect the line from the fuel pump to the CIS inlet. If fuel flows without the pump being on, the lo pressure pump will pull through it.
If it doesn't, well..... |
JStroud |
Aug 11 2014, 02:52 PM
Lo-Fi Version | Time is now: 8th June 2024 - 11:34 AM |
