Fuel pump question, Temporary switch to carbs |
JStroud |
Aug 11 2014, 07:59 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Ok I've pulled my 2.7 with CIS to do a rebuild, I've got a 2.7 with carbs I'm installing while my motor is down, trying to make it to RRC.
So my question, can I install the carb fuel pump and just leave my FI pump in place, will the carb pump be able to pull the gas thru the other pump( power disconnected ) or will I have to take it out. Or should I just use the FI pump and install a pressure regulator. The FI pump is in the front trunk(75-76 location) was thinking of just mounting the carb pump on the firewall in the engine compartment. This is just a temporary swap so trying to keep it simple, and easy to change back. Thanks, Jeff |
Mike Bellis |
Aug 11 2014, 06:24 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
It only take a little bit of hose to bypass around the FI pump.
(IMG:style_emoticons/default/WTF.gif) are you doing? |
JStroud |
Aug 11 2014, 07:34 PM
It only take a little bit of hose to bypass around the FI pump. (IMG:style_emoticons/default/WTF.gif) are you doing? I changed all my fuel lines to braided with AN fittings, so not quite that simple to bypass. Or maybe it is, do they make an AN coupler? But then can't remember if both sides are the same size. WTF am I doing......did you read the first post (IMG:style_emoticons/default/poke.gif) I'm being like you Mike, putting as many motors in my car as I can. (IMG:style_emoticons/default/lol-2.gif) This will be #4 in 3 years. (IMG:style_emoticons/default/w00t.gif) Jeff |
Mike Bellis |
Aug 11 2014, 09:10 PM
It only take a little bit of hose to bypass around the FI pump. (IMG:style_emoticons/default/WTF.gif) are you doing? I changed all my fuel lines to braided with AN fittings, so not quite that simple to bypass. Or maybe it is, do they make an AN coupler? But then can't remember if both sides are the same size. WTF am I doing......did you read the first post (IMG:style_emoticons/default/poke.gif) I'm being like you Mike, putting as many motors in my car as I can. (IMG:style_emoticons/default/lol-2.gif) This will be #4 in 3 years. (IMG:style_emoticons/default/w00t.gif) Jeff You're catching up for sure. Your mistake was putting the same manufacturer's engine in over and over. If you want to "one up" me, put in a Yugo engine. I won't even attempt that one... (IMG:style_emoticons/default/biggrin.gif) BTW, Summit Racing has AN to barb adapters in male & female... |
JStroud |
Aug 11 2014, 09:21 PM
It only take a little bit of hose to bypass around the FI pump. (IMG:style_emoticons/default/WTF.gif) are you doing? I changed all my fuel lines to braided with AN fittings, so not quite that simple to bypass. Or maybe it is, do they make an AN coupler? But then can't remember if both sides are the same size. WTF am I doing......did you read the first post (IMG:style_emoticons/default/poke.gif) I'm being like you Mike, putting as many motors in my car as I can. (IMG:style_emoticons/default/lol-2.gif) This will be #4 in 3 years. (IMG:style_emoticons/default/w00t.gif) Jeff You're catching up for sure. Your mistake was putting the same manufacturer's engine in over and over. If you want to "one up" me, put in a Yugo engine. I won't even attempt that one... (IMG:style_emoticons/default/biggrin.gif) BTW, Summit Racing has AN to barb adapters in male & female... Not catching up or trying, mine are pretty basic installs just different motors, yours are custom and very impressive. Thanks for the info on the fittings. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:04 PM |
