> D-Jet sputtering
JtoTheBeezy
post Aug 14 2014, 12:20 PM
With no consistency my 2.0 fi car will sputter and shutter. Its hard to tell weather its a lack of fuel or a lack of spark. Its fairly speratic but constant once the car is warm. What I usually have to do is stomp it or feather it past 4k rpm and it runs fine above 4k.
Things ive fixed/replaced
New oil and filter
new fuel filter
Checked/replaced any bad vacuume hoses
replaced and calibrated the tps
checked mps
checked aar. Stays closed 24/7 which is better than open randomly
new cap
new rotor
Adjusted timing to the best of my ability (IMG:style_emoticons/default/blink.gif)
I've owned this car for over a month now and it has never run properly due to this problem. Today im going to check the injector points and do a valve adjustment. I can hear the injectors firing with the key in the on position but they could still have issues I suppose. Help me... carbs are calling my name. (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/WTF.gif)
post Aug 14 2014, 04:22 PM
Check your fuel pressure, if high check your return line to see if it is blocked or crimped. If fuel pressure is OK pull your injectors, place them each in a jar then test them and watch for one that is shooting streams or stuck open. Don't drive it until you get a handle on it. That's way too much gas and your probably washing one or more cylinders with gas. Any gas smell on your oil dipstick?
- Lo-Fi Version Time is now: 16th April 2026 - 11:43 PM
