Fuel pump question, Temporary switch to carbs |
JStroud |
Aug 11 2014, 07:59 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Ok I've pulled my 2.7 with CIS to do a rebuild, I've got a 2.7 with carbs I'm installing while my motor is down, trying to make it to RRC.
So my question, can I install the carb fuel pump and just leave my FI pump in place, will the carb pump be able to pull the gas thru the other pump( power disconnected ) or will I have to take it out. Or should I just use the FI pump and install a pressure regulator. The FI pump is in the front trunk(75-76 location) was thinking of just mounting the carb pump on the firewall in the engine compartment. This is just a temporary swap so trying to keep it simple, and easy to change back. Thanks, Jeff |
SLITS |
Aug 15 2014, 01:40 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
You have a very small orifice (1/8"?) on the return stub (inside the tank) and it is doubtful if you can get sufficient fuel flow.
I have fixed a couple of cars that wouldn't run because of crossed fuel lines. Not your best idea yet. 3rd Image - 1st Post shows the outlet / return fittings |
Lo-Fi Version | Time is now: 1st June 2024 - 01:39 PM |
