> Quick 4x6 Speaker install, For those keeping the factory look
914Sixer
post Aug 15 2014, 07:54 PM
I am updating the sound in the orange 75. The factory speakers had crumbled. I pulled them out and went in search of some replacements. We all know that the speakers on the 914 were an odd duck mounting size. You have to also keep in mind that the speaker has to be low profile to clear the side wall. I found a set of Pyle coaxial speakers (4x6) that fit the objective. Of course, the speakers and mounts were not going to be plug and play but I found a way to make for a nice factory look fit.
I took the speakers apart and checked the mounting out. Mounts with grill would fit in the stock location mount with a little modification. I ground off about a 1/4" of plastic on each end of the mount to fit inside the speaker housing. Marked the mounts for notching and got out the files. Used a V file to start notch and then a round file for the mounting slot. Put the speakers back together and mounted them in the factory holes. I need longer screws. so I used the front turn signal lens screws, they were just the right length. I broke the speaker mounting clips in half and used it to secure the speaker mount to the factory grill.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
913B
post Aug 15 2014, 08:56 PM
Looks good, where did you buy the speakers from, were they expensive, I will be on a look out for a pair to do the same.
Great job Mark !
914Sixer   Quick 4x6 Speaker install   Aug 15 2014, 07:54 PM
porsche913b_sp   Looks good, where did you buy the speakers from, w...   Aug 15 2014, 08:56 PM
barefoot   Looks good, where did you buy the speakers from, ...   Aug 16 2014, 07:04 AM
mskala   Not sure I follow, are you saying you can make the...   Aug 15 2014, 09:15 PM
914Sixer   Yes, they will fit with the grill covers on the sp...   Aug 15 2014, 10:10 PM
914Sixer   Pictures added.   Aug 16 2014, 06:25 AM
porsche913b_sp   Hey Mark i am bumping your thread i am ready for s...   Nov 8 2014, 10:09 PM
914Sixer   They are what I would call average. Nothing excep...   Nov 9 2014, 07:37 AM
Mikey914   My recollection is the clearance in the back is a ...   Nov 9 2014, 12:59 PM
BeatNavy   My recollection is the clearance in the back is a...   Nov 9 2014, 06:04 PM
Mikey914   My recollection is the clearance in the back is ...   Nov 10 2014, 03:34 PM
914Sixer   These fit really well BUT you have to do the modif...   Nov 9 2014, 06:02 PM
JmuRiz   I've had luck with 4x6 plate speakers in my ca...   Nov 10 2014, 10:16 AM
bandjoey   Walmart off the shelf 200 watts max $25 pair ...   Nov 10 2014, 02:53 PM
Cairo94507   I just got a set of these Pyle speakers for my car...   Feb 14 2016, 09:34 AM
914Sixer   Dragging out old topic. I am going to do a update...   Jun 26 2021, 03:00 PM
DC_neun_vierzehn   Dragging out old topic. I am going to do a updat...   Jun 26 2021, 10:15 PM
914Sixer   Going in factory grills just like the top of threa...   Jun 27 2021, 06:10 AM
- Lo-Fi Version Time is now: 24th May 2026 - 05:01 AM
