Dizzy lifts up when turning by hand, In the build process |
jeffdon |
Aug 15 2014, 04:45 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Got my engine on the stand with heads on. When turning the engine over by hand, I am getting a little binding that I think is coming from the dizzy. It also wants to lift out of the hole by about a 1/4 inch. The hold down is tight. What could this be? I am turning the motor clock wise as I face the fan.
Cap'n Krusty |
Aug 15 2014, 06:33 PM
Could be the drive gear on the crank got banged up during the process, or that the washer is missing, or the distributor's not clamped down.
With a good flashlight you can see the drive gear from above. The Cap'n |
jeffdon |
Aug 15 2014, 10:07 PM
Could be the drive gear on the crank got banged up during the process, or that the washer is missing, or the distributor's not clamped down. With a good flashlight you can see the drive gear from above. The Cap'n I might have done a bit of boogering up of the drive gear. Washer is in there, I flipped the motor upside down an pulled out the gear, and verified the washer is there. Paranoid about droping it into the case. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:16 PM |
