Dizzy lifts up when turning by hand, In the build process |
jeffdon |
Aug 15 2014, 04:45 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Got my engine on the stand with heads on. When turning the engine over by hand, I am getting a little binding that I think is coming from the dizzy. It also wants to lift out of the hole by about a 1/4 inch. The hold down is tight. What could this be? I am turning the motor clock wise as I face the fan.
Cap'n Krusty |
Aug 15 2014, 06:33 PM
Could be the drive gear on the crank got banged up during the process, or that the washer is missing, or the distributor's not clamped down.
With a good flashlight you can see the drive gear from above. The Cap'n |
jeffdon |
Aug 15 2014, 10:07 PM
Could be the drive gear on the crank got banged up during the process, or that the washer is missing, or the distributor's not clamped down. With a good flashlight you can see the drive gear from above. The Cap'n I might have done a bit of boogering up of the drive gear. Washer is in there, I flipped the motor upside down an pulled out the gear, and verified the washer is there. Paranoid about droping it into the case. |
bdstone914 |
Aug 15 2014, 10:51 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Could be the drive gear on the crank got banged up during the process, or that the washer is missing, or the distributor's not clamped down. With a good flashlight you can see the drive gear from above. The Cap'n I might have done a bit of boogering up of the drive gear. Washer is in there, I flipped the motor upside down an pulled out the gear, and verified the washer is there. Paranoid about droping it into the case. When reinstalling the washer and spring first insert a thin rod and slide the washer and spring down the rod. Keeps them from dropping into the case. Figured that out after dropping a spring into the case. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:07 PM |
