4 Cyl. Header |
4 Cyl. Header |
aveale |
Aug 18 2004, 11:03 AM
Fun Times Group: Members Posts: 194 Joined: 18-August 04 From: Ottawa, Canada Member No.: 2,563 |
Hello,
Cracked Heat Exchanger. Broken Heart. Anyone have info on a replacement set of Headers (I only drive in the summer) or where to locate new Exchangers? i.e. success rate, vendors, installation difficulty. Thanx Tony |
Mueller |
Aug 18 2004, 12:01 PM
also, don't forget to check out the vendors forum here on the BBS, there is also European Racing Headers available
you really need to decide, do you want headers or heat exchangers? for heat exhangers that are a direct bolt-on, your options are: used or new stainless steel units (sold by the normal suspects, I believe HPH has them in stock right now) for headers, they are a bolt-on item as well (the best units use the seperate stub pipes such as the Tangerine and Eurorace and Triad.)....make sure you get the correct muffler since the factory unit will not work.... prices: $50 to $300+ for the heat exhangers $400 to $1200+ for the headers |
Lo-Fi Version | Time is now: 10th June 2024 - 01:03 PM |
