> Home made ultra-sonic FI cleaner
Mark Henry
post May 1 2003, 05:37 PM
that's what I do!
I had an old electric tool engraver lying around. I hose clamped the tip to nut and another hose clamp, and then I clamped it to a small Tupperware condiment container. I then put an injector in it and added FI cleaner till it just covered the injector.
Put on the top and plugged it in, it works great. I have cleaned a couple of injectors now including one with a seized pintle (sp?) that has now freed up.
Mark Henry
post May 1 2003, 07:13 PM
that's what I do!
Yep, wish I had a digi cam for this one!
You can't put a hose clamp on the tip of the engraver alone, too small, so I put the clamp around a nut and stuck the tip in a bit and tightened it up.
At the same time, I also put another clamp through the nut clamp set up and that one went around the container nice and tight.
It's working like a charm, you should see all the crap coming off of my injectors.
BUT it is noisier then the morning after beer Schlitz!!!
I turn it on, go in the house and turn on the stove timer for 30 minutes each, so I don't have listen to it.
(IMG:style_emoticons/default/beer.gif)
- Lo-Fi Version Time is now: 19th July 2025 - 05:16 PM
