Running Really Hot on the Track, I don't necessarily mean fast |
ww914 |
May 10 2014, 03:51 PM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Yesterday at Buttonwillow for our DE, the temperature was not all that hot, but I could only get in 2 laps at race speed before my CHT gauge started hollering at me. Here are the maximum values from yesterday:
Cyl #1 384 degrees Cyl #2 357 degrees Cyl #3 433 degrees Cyl #4 402 degrees I have the alarm set at 400 degrees, so each time it reached that temp, I backed off and let it cool down and finished each session with just a Sunday drive. Here's what I have: My engine is a 2270 built by Original Customs 2 40 DLRAs: 150 main jets 180 air correction jets 34 venturis 9164.2 emulsion tubes 75 idle jets 50 pump jets Both carbs are accurately sync'd and the a/f gauge shows between 13 - 14 all through the progression to WOT The timing is set to about 30 degrees I am running a stock cooling system with the thermostat and flaps working properly. I pulled engine tin to look for obstructions. None. I am running a Sebtrab 8 x 10 oil cooler but my temps are over 220 when pushing it hard. No fans. I am not sure where to go from here: alternate cooling, larger oil cooler, fans? Any suggestions would be appreciated. |
stugray |
Aug 23 2014, 11:58 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Will the headlights still function when done? Post more pics when you get a chance. I like what you got going on here. Looks nice so far! Shane Yes the headlights would still function. I didnt put them back in, but the entire bucket is still there & empty just with it's bottom cut out You have to cut out the metal below the headlight where it forms the funnel to the drain hole. (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1408859997.1.jpg) Here are the vents: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1408859890.1.jpg) Here's a shot with the finished vents installed: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1408859890.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1408859891.3.jpg) So, you have the two coolers hooked up in series? Is that just to cut down on the number of hoses to the rear? It must work. I like it. Yes the two are in series. and yes the system requires only one hose up & one hose back. In total it is almost 30 feet of 12AN hose. It took 3 extra quarts to fill it. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:21 PM |
