| Hine62 |
Aug 24 2014, 06:13 PM
Member ![]() ![]() Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
I've read "a lot" about the type 4, but still have some questions. My father worked on these engines when they where new, so he's teaching me how. I'm looking to build an type 4 engine with these parameters:
1.8l case 96mm cylinders 78mm crank Some questions: 1. If the stroke of the crank is increased, how does this affect the cylinders? Are the cylinders shimmed to the new stroke? Does someone make "78mm" cylinders"? Are the pistons/rods shorter/longer to make up the difference? 2. Should I look for a 2.0l case? From what I've read the cylinders fit in the 1.8L case. Are there any other benefits to the 2.0L case? 3. If I decide on 103mm cylinders, where should I send the case? (It will need to be machined for the crank anyway. Unless I decide to take a grinder to it (IMG:style_emoticons/default/biggrin.gif) ) 4. There are a lot of 'kits' to buy. Should I go with a kit or buy the parts separately? One advantage is kits come with gaskets, etc... I have more questions, but this will get me started. Thanks |
| Hine62 |
Aug 24 2014, 08:57 PM
Thanks Dave!
Could you explain the reduced base-circle cam? I assume the cam doesn't open the valve as far, but must keep the valve open longer to compensate lack of height. There is also the option to go with chevy or vw journals which would change the thickness of the rod end. |
Hine62 Engine building Aug 24 2014, 06:13 PM
02loftsmoor http://aapistons.com/engine-calculator
try this l... Aug 24 2014, 06:25 PM
Dave_Darling Some questions:
1. If the stroke of the crank is i... Aug 24 2014, 08:02 PM
Dave_Darling
A... Aug 25 2014, 08:30 AM
colingreene I just finished building what you are talking abou... Aug 24 2014, 09:19 PM
malcolm2 66mm and 71mm were the stock cranks. 93mm was th... Aug 25 2014, 07:43 AM
rhodyguy what they said. Aug 25 2014, 09:54 AM
bdstone914 A good starting point is to decide how much you ha... Aug 25 2014, 10:17 AM
Hine62 Thanks again everyone. Aug 25 2014, 10:32 AM
Racer Chris I can do the crankcase work here. Aug 25 2014, 11:10 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd November 2026 - 11:42 PM |
