Off Topic Question, Cut out on VW Jetta |
partwerks |
Aug 25 2014, 10:01 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Within the first 4 minutes of a cold engine, my 96 VW Jetta, has this thing where it will intermittently cut out. If you happen to be stopped, one of two things, if you let it run it's course, then the idle will fluctuate up and down from about 700 to 900 for about 5 seconds, or there abouts, and then the idle goes high to about 1200, for about 5 seconds, and comes down to normal idle.
On the other hand, if you slam the pedal down, and let back up quck, it tends to clear it out, and everything is normal. Otherwise, it runs just fine once it has it's fit. I've cleaned all the grounds that I know of, and replaced the coolant temp sensor, and throttle body, but not sure what is causing it?? I'm hoping someone might have an idea on what is causing it. It would almost make me think that it is something that when it first warms up? Any, thoughts, ideas, or suggestions? |
partwerks |
Aug 26 2014, 08:44 PM
There is no engine check light that is coming on.
I just put on new wires about 7 months ago, and distributor cap, maf, throttle body. I've been also told to check something called the ISV and the back of the intake manifold where that hose connects to? Not sure what that is? I'm not sure where it is located at: http://www.ebay.com/itm/New-Idle-Control-V...=p2054897.l4275 Not a complete cut out. Just like pulling a plug wire randomly off and on. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:45 AM |
