Shift bar linkage for /6 |
patssle |
Aug 29 2014, 07:48 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Well here's my next /6 conversion problem - my shift linkage hits the headers. After some research I can A) buy a new bar B) weld a new tube to mostly straighten it out and cut the bend off C) cut the ends off and rotate them so the bend faces the ground.
If I weld a new tube in (before cutting off the bend) - does it matter where I attach it to the existing tube? Will it rotate fine as long as the ends are not moved? Or should I just have one of the guys on the forum that convert these do it for me? A new bar is expensive and cutting the ends off makes me afraid if they are off just by a degree of ruining my shift rod. |
Jeffs9146 |
Aug 30 2014, 09:29 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I welded mine up! It doesn't have to look good as long as the end orientation and length is the same!
I welded up one end then tack welded the other and had someone shift while I watched the bar. I would grind off the weld and retack until I got a clean shift pattern. Then welded the rest up. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:46 AM |
