Electrical Question, Fuel Gauge reading jumps with lights on... |
jim_hoyland |
Sep 1 2014, 09:03 AM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
This has been bugging me for several years; every time the light switch is "ON", the fuel gauge level jumps up almost 1/4 tank.
I have a Getty 5 gauge dash: Clock, Speedo, Tach, Oil Press/Temp, and Fuel/Voltmeter. All the gauges share a common ground and common voltage source for the gauge lights; I'm wondering whether one or both need to be isolated to prevent the interference? Need some electriccal input here... (IMG:style_emoticons/default/smile.gif) |
stugray |
Sep 1 2014, 01:01 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
You have a bad ground.
When the lights are on, more current flows through the ground path from the light switch to the battery. A high resistance in the ground path means that the extra current causes a bigger voltage drop in the return path. This means that the gauge sees a smaller voltage from the sensor because the voltage drop in the ground path is shifting the reference voltage up. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:48 PM |
