Where does this wire go?, Broken wire - 1.7L D-jet |
stinkindiesel |
Sep 1 2014, 02:53 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
Car is a 1973 1.7 with original D-jet fuel injection. Wire looks to be tan or faded brown, and exits from the wiring harness under the intake plenum on the passenger side along with a green-red wire that goes to what I think is the oil pressure sensor. I've tried to capture it in the attached picture.
So, where is this wire supposed to go? Gary |
type47 |
Sep 1 2014, 02:59 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
brown wires are commonly the color of grounding wires on the 914. Don't recall any tan color coded wires so prob brown. There is a multi point ground connection on a 3 terminal spade connector on one of the case bolts at the rear of the engine. You could see if it traces to there but the other/loose end needs to find it's position. Throttle position sensor plug?
Here is the part of the schematic with the grn/red wire: http://www.pelicanparts.com/914/parts/Elec...lectric_74D.jpg Here is a diagram of the relay board the Cap'n is referring to: 12 pin plug located at lower right |
Lo-Fi Version | Time is now: 8th June 2024 - 12:38 PM |
