One side of the engine cooler than the other |
tornik550 |
Sep 3 2014, 07:09 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I dhave been playing around with my 2258 4cyl (dual weber 44 Idf's). The car drives great. I installed a new 4 channel head temp gauge. I noticed that the 1/2 side of the engine was about 30 degrees cooler. I thought maybe there was simply faulty measurement so I did a bunch of measurements with an ir thermometer. I checked headers case, heads, intakes, tin... and all measurements were about 30 degrees cooler on the 1/2 side. I also looked at all the spark plugs and they all look about the same. The car runs very well however I have a slight pop on decel that goes away if I slightly enrich cyl 2.
Any ideas? The head temps and header temps are normal on the 3/4 side so 30 degrees low on 1/2 side. |
ChrisFoley |
Sep 3 2014, 07:53 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Check your intake airflow at 3000 rpm to see if the 1/2 side carb is opening a little less than the 3/4 side carb. If one side of the engine is working harder it will be hotter.
Lo-Fi Version | Time is now: 9th June 2024 - 03:29 AM |
