> BOSCH D-Jetronic Megasquirt Adapter
shconer
post Sep 4 2014, 03:09 PM
I have built a prototype board that adapts the factory Bosch D-Jetronic card edge connector in my 1969 Squareback to the DB-37 connector of my Megasquirt 2. Also I retrofitted the factory pressure sensor with a modern sensor inside. With some small modifications to the Megasquirt board to accommodate the external MAP sensor. I have created a plug and play system that works with the factory harness and does not require any further modifications or additions. Alternately you could instead connect the standard Megasquirt onboard MAP sensor with a hose to the manifold and lose the factory appearance. I have done some testing with the prototype board and I am in the final stages of developing the final version. I have designed it to be compatible with early and late type 3 cars as well as all fuel injected 914's. Before I ordered PCBs and components I thought I would see if there is any interest out there for something like this. The final PCB is designed to mount inside of the factory case with room for the Megasquirt. An assembled adapter would cost approximately $80 CAD. This could be a cheaper solution for someone with a malfunctioning D-Jet ECU or a dual carb conversion. The factory idle control system still controls idle. This is a fuel only set up and the factory distributor and ignition is used. Also there is no provision for EGO feedback, it is a open loop system. This adapter works with MS1 or MS2 V3.0/3.52.
(IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864953.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864953.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864954.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864954.4.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864955.5.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864955.6.jpg)
shconer   BOSCH D-Jetronic Megasquirt Adapter   Sep 4 2014, 03:09 PM
Java2570   Thanks for posting here on the World, I saw this t...   Sep 4 2014, 03:27 PM
mapguy   This is really interesting. I'm not in the mar...   Sep 4 2014, 03:48 PM
shconer   This adapter is mostly a passive device. Because t...   Sep 4 2014, 04:42 PM
JamesM   This adapter is mostly a passive device. Because ...   Sep 4 2014, 05:30 PM
shconer   I am not sure I understand what you mean. My des...   Sep 4 2014, 10:14 PM
JamesM   On the injector circuit change, I just mean tha...   Oct 21 2014, 02:57 PM
shconer   Modified mounting holes. http://www.914world.com...   Sep 4 2014, 11:42 PM
Rotary'14   I like what you are doing! but I do have a ...   Sep 5 2014, 08:39 AM
monkeyboy   Robert, if you are looking to do that and you don...   Sep 6 2014, 07:44 AM
Rotary'14   Robert, if you are looking to do that and you don...   Sep 6 2014, 08:01 AM
Bebosko   Robert, if you are looking to do that and you don...   Feb 6 2015, 01:59 PM
carl07760   i am looking to convert a 2.0 EFI to webers dual c...   Oct 21 2014, 11:30 AM
r_towle   Can the fuel map be manipulated using this system?...   Oct 21 2014, 07:38 PM
shconer   I am still working on the design. I have since dis...   Oct 22 2014, 12:30 AM
ClayPerrine   This is an intriguing project, so I did some looki...   Oct 22 2014, 06:55 AM
shconer   This is an intriguing project, so I did some look...   Oct 22 2014, 08:22 PM
mr2by4   Funny you should say that. I had a similar idea...   Oct 22 2014, 09:53 PM
revhi109   I like everything I am seeing here. I really want ...   Oct 28 2014, 10:00 AM
monkeyboy   I have mine running already, but the adapter for t...   Feb 6 2015, 02:59 PM
- Lo-Fi Version Time is now: 24th November 2026 - 03:16 AM
