| shconer |
Sep 4 2014, 03:09 PM
Newbie ![]() Group: Members Posts: 6 Joined: 4-September 14 From: Canada Member No.: 17,863 Region Association: Canada |
I have built a prototype board that adapts the factory Bosch D-Jetronic card edge connector in my 1969 Squareback to the DB-37 connector of my Megasquirt 2. Also I retrofitted the factory pressure sensor with a modern sensor inside. With some small modifications to the Megasquirt board to accommodate the external MAP sensor. I have created a plug and play system that works with the factory harness and does not require any further modifications or additions. Alternately you could instead connect the standard Megasquirt onboard MAP sensor with a hose to the manifold and lose the factory appearance. I have done some testing with the prototype board and I am in the final stages of developing the final version. I have designed it to be compatible with early and late type 3 cars as well as all fuel injected 914's. Before I ordered PCBs and components I thought I would see if there is any interest out there for something like this. The final PCB is designed to mount inside of the factory case with room for the Megasquirt. An assembled adapter would cost approximately $80 CAD. This could be a cheaper solution for someone with a malfunctioning D-Jet ECU or a dual carb conversion. The factory idle control system still controls idle. This is a fuel only set up and the factory distributor and ignition is used. Also there is no provision for EGO feedback, it is a open loop system. This adapter works with MS1 or MS2 V3.0/3.52.
(IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864953.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864953.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864954.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864954.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864955.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/clubveedub.ca-17863-1409864955.6.jpg) |
| shconer |
Sep 4 2014, 10:14 PM
QUOTE Very cool. I have done the same thing on a couple of my cars but made the injector circuit change on the MS board itself (switched power through the injector drivers rather then ground) I am not sure I understand what you mean. My design switches on the high side of the injector through an unmodified factory harness. It does not switch through the ground. QUOTE I actually have a partially mocked up board based on the MS 2.2 design that will just solder directly to the d-jet edge connector. Life has been to busy for me to finish and send out for fab though. Duplicating Megasquirt boards in whole or part would violate Megasquirts patents and copyrights so I have designed an original adapter board as a Megasquirt accessory. I first tried to assemble a Megasquirt in a way that would allow high side switching but found it nearly impossible to do so and retain the flyback functionality. Also I think having a standard MS1/2 makes it easier to support. QUOTE How does the connection hold up with the traces just printed on the PCB like that? Considered that route as well but the connector is a bit fatter then a normal PCB, wasnt sure it would work. The board edge connector is the factory set up for the early Type 3. So in an effort to make it compatible with everything I went this route. In the testing I have done in my Squareback I have had no problems. I have connected and disconnected it many times during development and it is more durable than I thought it would be. Your commenting on the connector made me notice that the 914 ECU PCB has different mounting hole locations than the early T3 PCB. I will modify the adapter design to fit both. |
shconer BOSCH D-Jetronic Megasquirt Adapter Sep 4 2014, 03:09 PM
Java2570 Thanks for posting here on the World, I saw this t... Sep 4 2014, 03:27 PM
mapguy This is really interesting. I'm not in the mar... Sep 4 2014, 03:48 PM
shconer This adapter is mostly a passive device. Because t... Sep 4 2014, 04:42 PM
JamesM
This adapter is mostly a passive device. Because ... Sep 4 2014, 05:30 PM
JamesM
On the injector circuit change, I just mean tha... Oct 21 2014, 02:57 PM
shconer Modified mounting holes.
http://www.914world.com... Sep 4 2014, 11:42 PM
Rotary'14 I like what you are doing!
but I do have a ... Sep 5 2014, 08:39 AM
monkeyboy Robert, if you are looking to do that and you don... Sep 6 2014, 07:44 AM
Rotary'14
Robert, if you are looking to do that and you don... Sep 6 2014, 08:01 AM
Bebosko
Robert, if you are looking to do that and you don... Feb 6 2015, 01:59 PM
carl07760 i am looking to convert a 2.0 EFI to webers dual c... Oct 21 2014, 11:30 AM
r_towle Can the fuel map be manipulated using this system?... Oct 21 2014, 07:38 PM
shconer I am still working on the design. I have since dis... Oct 22 2014, 12:30 AM
ClayPerrine This is an intriguing project, so I did some looki... Oct 22 2014, 06:55 AM
shconer
This is an intriguing project, so I did some look... Oct 22 2014, 08:22 PM
mr2by4
Funny you should say that. I had a similar idea... Oct 22 2014, 09:53 PM
revhi109 I like everything I am seeing here. I really want ... Oct 28 2014, 10:00 AM
monkeyboy I have mine running already, but the adapter for t... Feb 6 2015, 02:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 03:16 AM |
