> CPU Overhaul
kpax914
post Sep 10 2014, 01:20 AM
I have a 73, 1.7 liter with everything new or checks out OK on the Fuel Injection. One culprit left the CPU. I'm in El Cajon Area of San Diego. Any rebuilders, besides sending to PelicanParts?
kpax914   CPU Overhaul   Sep 10 2014, 01:20 AM
76-914   Are you sure? Those are pretty much bullet proof i...   Sep 10 2014, 08:09 AM
kpax914   Are you sure? Those are pretty much bullet proof ...   Oct 5 2014, 08:17 PM
JamesM   ...I have exhausted everything else that could be...   Oct 6 2014, 10:53 PM
Chris Pincetich   If it starts and runs on all 4, but just runs bad...   Oct 7 2014, 01:49 PM
kpax914   ...I have exhausted everything else that could b...   Oct 7 2014, 06:14 PM
SirAndy   Are you sure? Those are pretty much bullet proof i...   Oct 6 2014, 01:23 AM
boxsterfan   Have you read this site? http://members.rennlist....   Sep 10 2014, 09:14 AM
Cap'n Krusty   That story is a bit suspect. In the 40 plus years...   Oct 5 2014, 09:41 PM
Tom   If it is running poorly at idle and more throttle ...   Oct 6 2014, 12:41 AM
stugray   Anyway I hooked up the 2 CPUs and same dproblem w...   Oct 6 2014, 08:19 AM
pilothyer   I think you nailed your problem in your post #4 wh...   Oct 6 2014, 08:35 AM
76-914   I have a spare MPS also if you want to check that....   Oct 6 2014, 08:40 AM
Dave_Darling   I have seen two failure modes so far from the ECU....   Oct 6 2014, 12:17 PM
dknechtly   I've had the same issue with the fuel pump not...   Oct 6 2014, 01:02 PM
Johny Blackstain   I seem to remember the ECU could also go bad if su...   Oct 6 2014, 12:20 PM
Drums66   .....It does happen!(CPU failure)but.............   Oct 6 2014, 01:15 PM
Jacob   What do you see when you hook up the vacuum gauge?...   Oct 6 2014, 01:46 PM
Chris Pincetich   I just replaced an ECU for my 1972 914 1.7 with D-...   Oct 6 2014, 04:33 PM
worn   I just replaced an ECU for my 1972 914 1.7 with D...   Oct 6 2014, 08:50 PM
kpax914   Hello everybody: It wasn't the CPU! But a ...   Nov 12 2014, 12:31 AM
type47   [color=#FF0000]?? But a combo of vacuum leak a...   Nov 12 2014, 09:03 AM
Racer Chris   [color=#FF0000]?? But a combo of vacuum leak ...   Nov 12 2014, 09:09 AM
type47   cold start injector mounted on the plenum OK, co...   Nov 12 2014, 09:23 AM
76-914   AA, There across the country. West coasters usuall...   Nov 12 2014, 08:29 AM
kpax914   AA, There across the country. West coasters usual...   Nov 13 2014, 05:31 PM
- Lo-Fi Version Time is now: 14th March 2026 - 11:18 AM
