> Trailing Arm Bushings, What material to select?
malcolm2
post Aug 28 2014, 03:32 PM
I need to replace the rear wheel bearings, so "while I am in there" I will also tackle the bushings.
Rubber looks to be the OEM choice but is hard to find with the exception of the elephant racing kit that includes the shafts and install tools. $300+ I used the Elephant bushings on the front.
I found poly-graphite to be the least expensive < $20 for a set of 4 bushings only
With Delrin as the middle of the road choice. @ $50 for a set of 4 bushings only
So what is the +/- of each material? Can you throw a few vendors out there?
My car is a daily driver?
Clark
malcolm2
post Sep 17 2014, 03:47 PM
Thanks for the info Chris, but yes the teflon impregnated poly bushings are installed in the tube. Seems to be a stainless steel tube. I don't think I would be set up to weld that material. I bet you tell your customers that is how yours go together? Maybe before they buy? (IMG:style_emoticons/default/blink.gif)
Pictures in previous post from Lonewolf. So here is a short video of the product. I have not installed the pivot arm. Mine are bad. Our friend Bruce has shipped me two and 4 nuts all freshly zinc plated, so it will be some time before I can do much more here.... (IMG:style_emoticons/default/chair.gif) Maybe Clint will call me back before the arms arrive.
Clark
https://www.youtube.com/watch?v=wGWdoG1fhjk
malcolm2   Trailing Arm Bushings   Aug 28 2014, 03:32 PM
Markl   I just put poly bushings on - PITA! They aren...   Aug 28 2014, 04:15 PM
JamesM   NO POLLY!!!! Rubber, or Elephant ...   Aug 28 2014, 05:40 PM
lonewolfe   NO POLLY!!!! Rubber, or Elephant...   Aug 28 2014, 08:20 PM
matthepcat   Im in the same boat. My retired race car has harde...   Aug 28 2014, 05:53 PM
jimkelly   http://www.paragon-products.com/Porsche-91...nsion...   Aug 28 2014, 06:46 PM
76-914   Mine are so GD loud I thought that I had missed a ...   Aug 28 2014, 07:35 PM
914_teener   +2 on Rubber for Street. Mine are quite. I insta...   Aug 28 2014, 07:38 PM
mgp4591   +2 on Rubber for Street. Mine are quite. I inst...   Aug 29 2014, 09:16 PM
914_teener   +2 on Rubber for Street. Mine are quite. I ins...   Sep 17 2014, 09:58 PM
lonewolfe   Here's the link to the Rebelracingproducts.com...   Aug 28 2014, 08:49 PM
malcolm2   Here's the link to the Rebelracingproducts.co...   Aug 28 2014, 09:23 PM
malcolm2   [quote name='lonewolfe' post='2079608' date='Aug ...   Aug 29 2014, 10:17 AM
lonewolfe   [quote name='lonewolfe' post='2079608' date='Aug ...   Aug 29 2014, 09:03 PM
malcolm2   [quote name='lonewolfe' post='2079608' date='Aug...   Aug 30 2014, 09:45 AM
JamesM   Here's the link to the Rebelracingproducts.co...   Aug 30 2014, 12:47 AM
lonewolfe   [quote name='lonewolfe' post='2079608' date='Aug ...   Aug 30 2014, 12:55 AM
Matt Romanowski   I think what Tangerine does is the best. They use ...   Aug 28 2014, 10:04 PM
malcolm2   :bump: for some coments   Aug 29 2014, 07:32 PM
02loftsmoor   All I add is thank you for bringing this up. about...   Aug 29 2014, 08:11 PM
MikeM   I looked at that page on the Rebel Racing website ...   Aug 29 2014, 09:31 PM
MikeM   I'll look forward to seeing them....   Aug 30 2014, 09:20 AM
MikeM   But these are poly bushings right? Not rubber. Wil...   Aug 30 2014, 09:59 AM
malcolm2   I'd love to hear from someone that actually ...   Aug 30 2014, 10:11 AM
MikeM   I'm pretty sure they have the wrong image ther...   Aug 30 2014, 10:26 AM
lonewolfe   These bushings fit around the trailing arm shaft a...   Aug 30 2014, 02:20 PM
jimkelly   I think with elephant, it is not the urethane that...   Aug 30 2014, 02:59 PM
MikeM   With respect to the rear trailing arm bushings, if...   Aug 30 2014, 05:33 PM
MikeM   Bump for comments??   Aug 31 2014, 09:07 AM
lonewolfe   Both are good high quality solutions. For me, the ...   Aug 31 2014, 01:13 PM
shane   Both are good high quality solutions. For me, the...   Aug 31 2014, 04:13 PM
malcolm2   UPDATE: I conversed with Jonathon and Clint at Re...   Sep 9 2014, 07:52 AM
chads74   UPDATE: I conversed with Jonathon and Clint at R...   Sep 9 2014, 08:20 AM
malcolm2   Please update once you get the rebel bushings. ...   Sep 13 2014, 11:09 AM
crash914   squeaking sucks, that's all I hear on my video...   Sep 9 2014, 10:48 AM
HalfMoon   So odd. I did poly's on my rears with zerks an...   Sep 9 2014, 09:14 PM
MikeM   It would be great if you would continue to keep us...   Sep 13 2014, 11:19 AM
Larmo63   We are all waiting to see these mythical parts…â...   Sep 13 2014, 11:46 AM
malcolm2   We are all waiting to see these mythical parts…...   Sep 15 2014, 01:46 PM
lonewolfe   I finally got time to take some pictures of the Re...   Sep 15 2014, 08:58 PM
MikeM   Pictures say a thousand words!!! Than...   Sep 16 2014, 08:19 AM
IanS   oooh shiny! Interesting one piece design rath...   Sep 16 2014, 12:00 PM
lonewolfe   oooh shiny! Interesting one piece design rat...   Sep 16 2014, 01:07 PM
malcolm2   USPS tracking tells me that mine are now OUT FOR D...   Sep 16 2014, 02:19 PM
lonewolfe   Yes, the threaded shafts that go through the RR m...   Sep 16 2014, 05:45 PM
malcolm2   Yes, the threaded shafts that go through the RR ...   Sep 16 2014, 07:00 PM
Racer Chris   Or should I just use the rusted pivot arm? Cl...   Sep 16 2014, 07:05 PM
lonewolfe   I'd replace them if they badly rusted. You can...   Sep 16 2014, 07:07 PM
Eric_Shea   Call a local metal plater like (Google is your fri...   Sep 16 2014, 08:45 PM
malcolm2   Call a local metal plater like (Google is your fr...   Sep 16 2014, 09:10 PM
lonewolfe   Hey Eric! The Rebelracingproducts front bushin...   Sep 16 2014, 09:13 PM
Racer Chris   Using factory shafts with precision bearing or bus...   Sep 16 2014, 09:15 PM
914_teener   Using factory shafts with precision bearing or bu...   Sep 16 2014, 09:34 PM
malcolm2   :bump: bump for more conversation on installing ...   Sep 17 2014, 01:59 PM
Racer Chris   :bump: bump for more conversation on installing...   Sep 17 2014, 02:13 PM
malcolm2   Thanks for the info Chris, but yes the teflon impr...   Sep 17 2014, 03:47 PM
malcolm2   The phone just rang, Jonathon says the answer is J...   Sep 17 2014, 06:08 PM
JamesM   When I got my rebel setup for the fronts I was fee...   Sep 17 2014, 10:52 PM
jd74914   I am a little suspect of the shaft fit on the rea...   Sep 18 2014, 06:26 AM
malcolm2   oops   Sep 18 2014, 12:02 PM
malcolm2   double oops   Sep 18 2014, 12:03 PM
malcolm2   Do the PTFE inserts spin in the tube or are they...   Sep 18 2014, 12:03 PM
Racer Chris   2ndly I mentioned to him that the 2nd rebel ass...   Sep 18 2014, 12:56 PM
malcolm2   2ndly I mentioned to him that the 2nd rebel as...   Sep 18 2014, 03:16 PM
worn   [quote name='Racer Chris' post='2087730' date='Se...   Sep 18 2014, 06:58 PM
lonewolfe   [quote name='JamesM' post='2087550' date='Sep 17 ...   Sep 19 2014, 10:29 PM
malcolm2   Hey Clark! Did you install the rear control...   Sep 20 2014, 08:39 AM
JamesM   [i][b]However, I have decided to return the bushi...   Sep 21 2014, 01:41 AM
Matt Romanowski   I've only done the fronts and was worried abou...   Sep 18 2014, 10:55 AM
crash914   JB weld is some wonderful stuff....I rebuilt some ...   Sep 18 2014, 11:17 AM
Racer Chris   The fronts are very different than the rear with r...   Sep 18 2014, 11:31 AM
914_teener   Looks right. Just make sure that the thrust surfa...   Sep 18 2014, 12:48 PM
lonewolfe   I am totally gung-ho on the Rebel Racing front con...   Sep 18 2014, 03:10 PM
a few loose screws   Very glad I read through this post.I was intereste...   Sep 20 2014, 06:16 AM
Highland   Would the Tangerine Racing trailing arm assembly b...   Sep 20 2014, 09:12 AM
malcolm2   Would the Tangerine Racing trailing arm assembly ...   Sep 20 2014, 09:26 AM
MikeM   I am surprised that Rebel Racing has not been invo...   Sep 20 2014, 09:44 AM
Krieger   I installed the Elephant Poly Bronze kits front an...   Sep 20 2014, 11:46 AM
Philip W.   My rear trailing arms were newly powder coated by ...   Sep 21 2014, 05:33 AM
57lincolnman   I need to replace the rear wheel bearings, so ...   Sep 21 2014, 08:44 PM
Rob-O   I lightly skimmed this thread but thought I'd ...   Sep 22 2014, 02:03 PM
malcolm2   UPDATE: Rebel stuff has been returned and my VISA...   Oct 2 2014, 07:10 PM
- Lo-Fi Version Time is now: 6th November 2026 - 02:13 AM
