| AvalonFal |
Sep 17 2014, 04:11 PM
Member ![]() ![]() Group: Members Posts: 487 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Got a 6V, 3 post Ford relay from ebay for my "74 2.0L Wired it up per the many threads on the subject on this and other boards.
My understanding of its operation is that 1 large post always has 12V (from battery) and the other 2 posts (small "S" and the other large one back to the starter) have 12V when the key is ON. Is this correct?? I'm not getting 12V at the large post that runs back to the starter. I'm thinking the Ford relay is defective. Any thoughts from Ford relay users?? Paul |
| busmech |
Sep 17 2014, 08:04 PM
Member ![]() ![]() Group: Members Posts: 68 Joined: 12-April 09 From: Daly City Ca Member No.: 10,258 Region Association: Northern California |
The 2 small terminals are for the coil. One needs power and the other one needs to go to ground. The power one is from the start circuit so it will only be on when you turn the key to start.
| AvalonFal |
Sep 17 2014, 08:18 PM
The 2 small terminals are for the coil. One needs power and the other one needs to go to ground. The power one is from the start circuit so it will only be on when you turn the key to start. It's a 3 post relay, so there's only 1 small post. It's grounded through the mounting bracket. Paul |
AvalonFal ? about 6V Ford Relay Sep 17 2014, 04:11 PM
Jeffs9146
Got a 6V, 3 post Ford relay from ebay for my ... Sep 17 2014, 04:19 PM
AvalonFal
Because I read the following in an Aug. 19, ... Sep 17 2014, 06:18 PM
76-914 Maybe a visual would help.
Sep 17 2014, 04:45 PM
SLITS
Got a 6V, 3 post Ford relay from ebay for my ... Sep 17 2014, 04:59 PM
AvalonFal
You won't get 12 VDC to the large post that ... Sep 17 2014, 06:31 PM
SLITS
You won't get 12 VDC to the large post that... Sep 17 2014, 06:41 PM
76-914 It's just a different version. Does the same t... Sep 17 2014, 06:46 PM
busmech Depending on the coil design it might need to be g... Sep 17 2014, 08:18 PM
worn
Got a 6V, 3 post Ford relay from ebay for my ... Sep 17 2014, 08:59 PM
Mark Henry :agree:
The ford solenoid needs to be a grounded.... Sep 17 2014, 09:02 PM
Mark Henry Jump a wire straight from the battery to the small... Sep 17 2014, 09:06 PM
AvalonFal
Any description of why you want to use a relay to... Sep 17 2014, 09:29 PM
AvalonFal I connected 12V to the Ford relay "S" po... Sep 18 2014, 11:14 AM
SLITS
I connected 12V to the Ford relay "S" p... Sep 18 2014, 12:40 PM
AvalonFal
I connected 12V to the Ford relay "S" ... Sep 18 2014, 03:08 PM
jwc914
[quote name='SLITS' post='2087720' date='Sep 18 2... Sep 18 2014, 04:44 PM
worn
[quote name='SLITS' post='2087720' date='Sep 18 ... Sep 18 2014, 06:10 PM
stugray
I joked about this on a previous "how to wi... Sep 18 2014, 01:30 PM
worn
I joked about this on a previous "how to w... Sep 18 2014, 06:07 PM
Jeffs9146 E-Bay Motorcraft Relay Sep 18 2014, 05:50 PM
Tom The solenoid pull-in current is 35 Amps. Hold-in c... Sep 19 2014, 01:40 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th November 2026 - 11:40 AM |
