| malcolm2 |
Aug 28 2014, 03:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,761 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
I need to replace the rear wheel bearings, so "while I am in there" I will also tackle the bushings.
Rubber looks to be the OEM choice but is hard to find with the exception of the elephant racing kit that includes the shafts and install tools. $300+ I used the Elephant bushings on the front. I found poly-graphite to be the least expensive < $20 for a set of 4 bushings only With Delrin as the middle of the road choice. @ $50 for a set of 4 bushings only So what is the +/- of each material? Can you throw a few vendors out there? My car is a daily driver? Clark |
| ChrisFoley |
Sep 18 2014, 11:31 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,035 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
The fronts are very different than the rear with regard to the assembly and the forces involved.
The a-arm (both F&R) brackets are retained by bolts. The bushing flanges and the flanges on the a-arm prevent fore-aft movement which has only a small force component. The ends of the trailing arm assembly have to resist all the sideways forces from cornering, but the flanges aren't flat enough to support a proper thrust washer. Not only that, the thickness of the thrust washers/bearings must add exactly the correct amount so the trailing arm pivots freely without sideways free play. I've measured a significant length variation among a large collection of stock pivot shafts. Since the steel sleeve has to be slid all the way through the trailing arm to install it, using any kind of liquid "glue" is questionable IMO. |
malcolm2 Trailing Arm Bushings Aug 28 2014, 03:32 PM
Markl I just put poly bushings on - PITA! They aren... Aug 28 2014, 04:15 PM
JamesM NO POLLY!!!!
Rubber, or Elephant ... Aug 28 2014, 05:40 PM
lonewolfe
NO POLLY!!!!
Rubber, or Elephant... Aug 28 2014, 08:20 PM
matthepcat Im in the same boat. My retired race car has harde... Aug 28 2014, 05:53 PM
jimkelly http://www.paragon-products.com/Porsche-91...nsion... Aug 28 2014, 06:46 PM
76-914 Mine are so GD loud I thought that I had missed a ... Aug 28 2014, 07:35 PM
914_teener +2 on Rubber for Street.
Mine are quite.
I insta... Aug 28 2014, 07:38 PM
mgp4591
Mine are quite.
I inst... Aug 29 2014, 09:16 PM
914_teener
Mine are quite.
I ins... Sep 17 2014, 09:58 PM
lonewolfe Here's the link to the Rebelracingproducts.com... Aug 28 2014, 08:49 PM
malcolm2
Here's the link to the Rebelracingproducts.co... Aug 28 2014, 09:23 PM
malcolm2
[quote name='lonewolfe' post='2079608' date='Aug ... Aug 29 2014, 10:17 AM
lonewolfe
[quote name='lonewolfe' post='2079608' date='Aug ... Aug 29 2014, 09:03 PM
malcolm2
[quote name='lonewolfe' post='2079608' date='Aug... Aug 30 2014, 09:45 AM
JamesM
Here's the link to the Rebelracingproducts.co... Aug 30 2014, 12:47 AM
lonewolfe
[quote name='lonewolfe' post='2079608' date='Aug ... Aug 30 2014, 12:55 AM
Matt Romanowski I think what Tangerine does is the best. They use ... Aug 28 2014, 10:04 PM
malcolm2 :bump: for some coments Aug 29 2014, 07:32 PM
02loftsmoor All I add is thank you for bringing this up. about... Aug 29 2014, 08:11 PM
MikeM I looked at that page on the Rebel Racing website ... Aug 29 2014, 09:31 PM
MikeM I'll look forward to seeing them.... Aug 30 2014, 09:20 AM
MikeM But these are poly bushings right? Not rubber. Wil... Aug 30 2014, 09:59 AM
malcolm2
I'd love to hear from someone that actually ... Aug 30 2014, 10:11 AM
MikeM I'm pretty sure they have the wrong image ther... Aug 30 2014, 10:26 AM
lonewolfe These bushings fit around the trailing arm shaft a... Aug 30 2014, 02:20 PM
jimkelly I think with elephant, it is not the urethane that... Aug 30 2014, 02:59 PM
MikeM With respect to the rear trailing arm bushings, if... Aug 30 2014, 05:33 PM
MikeM Bump for comments?? Aug 31 2014, 09:07 AM
lonewolfe Both are good high quality solutions. For me, the ... Aug 31 2014, 01:13 PM
shane
Both are good high quality solutions. For me, the... Aug 31 2014, 04:13 PM
malcolm2 UPDATE: I conversed with Jonathon and Clint at Re... Sep 9 2014, 07:52 AM
chads74
UPDATE: I conversed with Jonathon and Clint at R... Sep 9 2014, 08:20 AM
malcolm2
Please update once you get the rebel bushings.
... Sep 13 2014, 11:09 AM
crash914 squeaking sucks, that's all I hear on my video... Sep 9 2014, 10:48 AM
HalfMoon So odd.
I did poly's on my rears with zerks an... Sep 9 2014, 09:14 PM
MikeM It would be great if you would continue to keep us... Sep 13 2014, 11:19 AM
Larmo63 We are all waiting to see these mythical parts…â... Sep 13 2014, 11:46 AM
malcolm2
We are all waiting to see these mythical parts…... Sep 15 2014, 01:46 PM
lonewolfe I finally got time to take some pictures of the Re... Sep 15 2014, 08:58 PM
MikeM Pictures say a thousand words!!! Than... Sep 16 2014, 08:19 AM
IanS oooh shiny! Interesting one piece design rath... Sep 16 2014, 12:00 PM
lonewolfe
oooh shiny! Interesting one piece design rat... Sep 16 2014, 01:07 PM
malcolm2 USPS tracking tells me that mine are now OUT FOR D... Sep 16 2014, 02:19 PM
lonewolfe Yes, the threaded shafts that go through the RR m... Sep 16 2014, 05:45 PM
malcolm2
Yes, the threaded shafts that go through the RR ... Sep 16 2014, 07:00 PM
Racer Chris
Or should I just use the rusted pivot arm?
Cl... Sep 16 2014, 07:05 PM
lonewolfe I'd replace them if they badly rusted. You can... Sep 16 2014, 07:07 PM
Eric_Shea Call a local metal plater like (Google is your fri... Sep 16 2014, 08:45 PM
malcolm2
Call a local metal plater like (Google is your fr... Sep 16 2014, 09:10 PM
lonewolfe Hey Eric! The Rebelracingproducts front bushin... Sep 16 2014, 09:13 PM
Racer Chris Using factory shafts with precision bearing or bus... Sep 16 2014, 09:15 PM
914_teener
Using factory shafts with precision bearing or bu... Sep 16 2014, 09:34 PM
malcolm2 :bump:
bump for more conversation on installing ... Sep 17 2014, 01:59 PM
Racer Chris
:bump:
bump for more conversation on installing... Sep 17 2014, 02:13 PM
malcolm2 Thanks for the info Chris, but yes the teflon impr... Sep 17 2014, 03:47 PM
malcolm2 The phone just rang, Jonathon says the answer is J... Sep 17 2014, 06:08 PM
JamesM When I got my rebel setup for the fronts I was fee... Sep 17 2014, 10:52 PM
jd74914
I am a little suspect of the shaft fit on the rea... Sep 18 2014, 06:26 AM
malcolm2 oops Sep 18 2014, 12:02 PM
malcolm2 double oops Sep 18 2014, 12:03 PM
malcolm2
Do the PTFE inserts spin in the tube or are they... Sep 18 2014, 12:03 PM
Racer Chris
2ndly I mentioned to him that the 2nd rebel ass... Sep 18 2014, 12:56 PM
malcolm2
2ndly I mentioned to him that the 2nd rebel as... Sep 18 2014, 03:16 PM
worn
[quote name='Racer Chris' post='2087730' date='Se... Sep 18 2014, 06:58 PM
lonewolfe
[quote name='JamesM' post='2087550' date='Sep 17 ... Sep 19 2014, 10:29 PM
malcolm2
Hey Clark!
Did you install the rear control... Sep 20 2014, 08:39 AM
JamesM
[i][b]However, I have decided to return the bushi... Sep 21 2014, 01:41 AM
Matt Romanowski I've only done the fronts and was worried abou... Sep 18 2014, 10:55 AM
crash914 JB weld is some wonderful stuff....I rebuilt some ... Sep 18 2014, 11:17 AM
914_teener Looks right.
Just make sure that the thrust surfa... Sep 18 2014, 12:48 PM
lonewolfe I am totally gung-ho on the Rebel Racing front con... Sep 18 2014, 03:10 PM
a few loose screws Very glad I read through this post.I was intereste... Sep 20 2014, 06:16 AM
Highland Would the Tangerine Racing trailing arm assembly b... Sep 20 2014, 09:12 AM
malcolm2
Would the Tangerine Racing trailing arm assembly ... Sep 20 2014, 09:26 AM
MikeM I am surprised that Rebel Racing has not been invo... Sep 20 2014, 09:44 AM
Krieger I installed the Elephant Poly Bronze kits front an... Sep 20 2014, 11:46 AM
Philip W. My rear trailing arms were newly powder coated by ... Sep 21 2014, 05:33 AM
57lincolnman
I need to replace the rear wheel bearings, so ... Sep 21 2014, 08:44 PM
Rob-O I lightly skimmed this thread but thought I'd ... Sep 22 2014, 02:03 PM
malcolm2 UPDATE: Rebel stuff has been returned and my VISA... Oct 2 2014, 07:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th November 2026 - 02:13 AM |
