Trailing Arm Bushings, What material to select? |
malcolm2 |
Aug 28 2014, 03:32 PM
I need to replace the rear wheel bearings, so "while I am in there" I will also tackle the bushings.
Rubber looks to be the OEM choice but is hard to find with the exception of the elephant racing kit that includes the shafts and install tools. $300+ I used the Elephant bushings on the front. I found poly-graphite to be the least expensive < $20 for a set of 4 bushings only With Delrin as the middle of the road choice. @ $50 for a set of 4 bushings only So what is the +/- of each material? Can you throw a few vendors out there? My car is a daily driver? Clark |
914_teener |
Sep 18 2014, 12:48 PM
914 Guru Group: Members Posts: 5,200 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Looks right.
Just make sure that the thrust surfaces....especially the serrated portion is engaged against the suspension console and that it is tight. At the end of the day the control arm rotates around the pivot shaft. If the pivot shaft end up coming loose, this could add up to a bad day. Opps.....forgot to add: Align everything...after you are done. |
Lo-Fi Version | Time is now: 22nd May 2024 - 11:24 PM |
