> Suby axle and DOJ cv issue., 25 splines to the diff, 30 splines to the axle. What CV is this?
ruby914
post Aug 12 2014, 11:30 AM
I put a 02 WRX motor in my 914 and have a MY03 TY754VN2BA trans staged for transplant.
I needed inboard CV’s so I went down to the local pick-a-part and got CV’s off of a 99 Legacy.
One CV was green the other was black. More so the black had ball and cage, the green had the tri roller setup. Both CV’s had the 25 spline count so I felt all was good.
Next, I sent a set of 914 axles with the inner race from the black CV to a machine shop to have them re-splined to fit the inner CV race.
When I got them back they fit great. Problem is the green CV has a different spline count inside the CV. I didn't notice this before.
ID on the green is 9 SFJ 82 NTN A R 3 T 29 splines to the drive shaft "trunnion" (inner race).
ID on the black is DOJ 87 AC NTN 30 splines to the drive shaft.
So my axles were splined for the DOJ 87 AC
Was this a mistake? I have searched the net and can’t find what model cars these fit. Can’t tell if it was proper for the car it came from. I think not.
I would hope to have chosen something common.
Anyone have an idea what cars these come from?
I would like one more DOJ 87 AC to get the project moving.
Maybe I should I re-spline a 2nd set of axles to something more common?
I am a little confused here. I think it was after 04 that the CV had shafts to the trany and the inner race "trunnion" was 30 splines. Did any of you do axles for the 03 and what spline count did you use?
post Aug 13 2014, 02:39 PM
Whichever one you use will be stronger than the Type4 CV.
ruby914
post Sep 18 2014, 11:10 AM
QUOTE(76-914 @ Aug 13 2014, 01:39 PM) *
After all I have found on CVs, I am starting to question if this is correct.
All this work looking for the CV to fit a 30 spline shaft lead me to Subaru Hi output applications.. Legacy TT, STI, JDM. Even with this larger DOJ 87 AC on the inboard side, the balls are only about .660 where the Type4 CV has something like .675.
Outter race OD is about the same.
The guy I got my DOJ 87 AC from had 1 good one out of 3 from his STI.
So if his STI is AWD and we are feeding the same power (give or take) to two wheels, wouldn't we need something considerably stronger?
I am starting to think we just have not seen or heard of the Suby CVs breaking on the 914s yet.
After breaking an inboard CV on the 901 trany and beating the life out if the starter, I am also starting to question the "CV fuse" thinking. That may still be good if your racing but I would think on the street your tires should be a good breaking point?
post Sep 18 2014, 03:10 PM
QUOTE(ruby914 @ Sep 18 2014, 10:10 AM) *
Well first off Mike, you'd be crazy if you didn't question me. (IMG:style_emoticons/default/av-943.gif) As far as power to 2 wheels. The 914 is much lighter, your only spinning one wheel not 4. Where are you with this? Did you ever get your axles re-splined?
ruby914
post Sep 19 2014, 02:14 AM
QUOTE(76-914 @ Sep 18 2014, 02:10 PM) *
Yea Kent, the lighter car is a big consideration as well as what rubber you are running. I do totally agree that it is better to break a CV than a trany but for as light as a 914 is it would be nice if the complete drive-train would hold up to the power plant with confidence.
That takes me to the trany. I think it was The Heaterguy that I saw on NASIOC picking brains on why he was breaking Subaru transmissions. It got me wondering if putting the AWD power into 2wd is making a new weak link? Just thinking out loud.
Yes... the axles (IMG:style_emoticons/default/headbang.gif) I finally found the DOJ 87 AC. With the 30 spline shaft.
They cam from an 03 STI. The guy was great to break them down and clean all the grease out. He had 1 good one out of 3. Seems he drove his car hard.
Do you remember the comment about my axles being something like 15" and it would be hard to cut them down to 18"?
That was in your build thread. Later I called you, I think you said you took off 30 ~ 32mm. I felt safe with that and I sent them to Dutchman.
I got them back in no time.
I bought axles from bddrcfjfvy because I wanted to drive the car with little down time. Just pull my trany and axles and swap the suby trany and new axles.
Well, I don't know what he sent me but they were not 914 axles. (IMG:style_emoticons/default/lol-2.gif)
That 15" thing should have been a clue.
Do you know any one doing a Bug Suby swap?
So.. I am riding the KTM to work. Car is all 914 now, on jack stands.
I sent my axles off yesterday.
DBCooper
post Sep 19 2014, 06:57 AM
14's in the 13's with ATTITUDE
QUOTE(ruby914 @ Sep 19 2014, 01:14 AM) *
I don't see that the Subaru drag racers break as many Subaru CV's as I seem to break 914 CV's. That seems a reasonable indication, but we're going to know the real answer to that question pretty soon. As more people are up and running with inner Subaru CV's and outer Porsche we'll have a direct comparison and see which go first. I'm betting on the 40 year old 914's but am curious too.
I'd be cautious reading much into that since he's running about 550 wheel HP through race slicks. That's the equivalent of about two STi engines, a lot more than any of us will ever see. Now that I think about it I'm impressed that he didn't break the CV's first. Wonder what he's using.
I'm just about to send some axles off to be re-splined. Wish I could wait to know the answers to these questions for sure, but can't. But I'm really curious. I think I'll go the 19 inch length too, seems logical.
ruby914   Suby axle and DOJ cv issue.   Aug 12 2014, 11:30 AM
ruby914   Here are some of the links I have to work with: h...   Aug 12 2014, 12:05 PM
76-914   Mike, these are what I used, IIRC. ID on the gr...   Aug 12 2014, 06:19 PM
ruby914   Mike, these are what I used, IIRC. ID on the g...   Aug 13 2014, 11:56 AM
76-914   Whichever one you use will be stronger than the Ty...   Aug 13 2014, 02:39 PM
ruby914   Whichever one you use will be stronger than the T...   Aug 15 2014, 11:43 PM
ruby914   Whichever one you use will be stronger than the T...   Sep 18 2014, 11:10 AM
76-914   Whichever one you use will be stronger than the ...   Sep 18 2014, 03:10 PM
ruby914   [quote name='ruby914' post='2087686' date='Sep 18...   Sep 19 2014, 02:14 AM
DBCooper   I am starting to think we just have not seen or h...   Sep 19 2014, 06:57 AM
rnellums   A problem you might be running into is remanufactu...   Aug 16 2014, 02:55 PM
ruby914   A problem you might be running into is remanufact...   Aug 16 2014, 10:27 PM
rnellums   I just got back from RRC in Moab, and on the way t...   Sep 18 2014, 06:18 PM
mgp4591   I just got back from RRC in Moab, and on the way ...   Sep 18 2014, 10:15 PM
DBCooper   I just got back from RRC in Moab, and on the way ...   Dec 4 2014, 03:38 PM
Amenson   OK, now I'm curious too. Not my car but thi...   Dec 5 2014, 12:17 PM
Chris H.   I had one of my outer (914) CVs do that almost imm...   Sep 18 2014, 06:47 PM
DBCooper   I've broken three CV's (too much fun), all...   Sep 18 2014, 08:31 PM
ruby914   I've broken three CV's (too much fun), al...   Sep 19 2014, 02:53 AM
76-914   I'm having good luck with mine staying on but ...   Sep 19 2014, 08:31 AM
ruby914   I'm having good luck with mine staying on but...   Sep 19 2014, 09:44 AM
ruby914   Parts links: http://rockforddriveline.com/New_Par...   Sep 19 2014, 10:32 AM
76-914   I really need to slow down and read these posts mo...   Sep 19 2014, 05:53 PM
76-914   No help here Paul. I'm running Full Suby inner...   Dec 5 2014, 09:58 AM
rnellums   No help here Paul. I'm running Full Suby inne...   Dec 5 2014, 07:07 PM
- Lo-Fi Version Time is now: 7th October 2026 - 11:27 PM
