> Suby axle and DOJ cv issue., 25 splines to the diff, 30 splines to the axle. What CV is this?
ruby914
post Aug 12 2014, 11:30 AM
I put a 02 WRX motor in my 914 and have a MY03 TY754VN2BA trans staged for transplant.
I needed inboard CV’s so I went down to the local pick-a-part and got CV’s off of a 99 Legacy.
One CV was green the other was black. More so the black had ball and cage, the green had the tri roller setup. Both CV’s had the 25 spline count so I felt all was good.
Next, I sent a set of 914 axles with the inner race from the black CV to a machine shop to have them re-splined to fit the inner CV race.
When I got them back they fit great. Problem is the green CV has a different spline count inside the CV. I didn't notice this before.
ID on the green is 9 SFJ 82 NTN A R 3 T 29 splines to the drive shaft "trunnion" (inner race).
ID on the black is DOJ 87 AC NTN 30 splines to the drive shaft.
So my axles were splined for the DOJ 87 AC
Was this a mistake? I have searched the net and can’t find what model cars these fit. Can’t tell if it was proper for the car it came from. I think not.
I would hope to have chosen something common.
Anyone have an idea what cars these come from?
I would like one more DOJ 87 AC to get the project moving.
Maybe I should I re-spline a 2nd set of axles to something more common?
I am a little confused here. I think it was after 04 that the CV had shafts to the trany and the inner race "trunnion" was 30 splines. Did any of you do axles for the 03 and what spline count did you use?
post Sep 19 2014, 05:53 PM
I really need to slow down and read these posts more carefully. I have some 914 cages, not Suby. Sorry Mike. (IMG:style_emoticons/default/sad.gif)
ruby914   Suby axle and DOJ cv issue.   Aug 12 2014, 11:30 AM
ruby914   Here are some of the links I have to work with: h...   Aug 12 2014, 12:05 PM
76-914   Mike, these are what I used, IIRC. ID on the gr...   Aug 12 2014, 06:19 PM
ruby914   Mike, these are what I used, IIRC. ID on the g...   Aug 13 2014, 11:56 AM
76-914   Whichever one you use will be stronger than the Ty...   Aug 13 2014, 02:39 PM
ruby914   Whichever one you use will be stronger than the T...   Aug 15 2014, 11:43 PM
ruby914   Whichever one you use will be stronger than the T...   Sep 18 2014, 11:10 AM
76-914   Whichever one you use will be stronger than the ...   Sep 18 2014, 03:10 PM
ruby914   [quote name='ruby914' post='2087686' date='Sep 18...   Sep 19 2014, 02:14 AM
DBCooper   I am starting to think we just have not seen or h...   Sep 19 2014, 06:57 AM
rnellums   A problem you might be running into is remanufactu...   Aug 16 2014, 02:55 PM
ruby914   A problem you might be running into is remanufact...   Aug 16 2014, 10:27 PM
rnellums   I just got back from RRC in Moab, and on the way t...   Sep 18 2014, 06:18 PM
mgp4591   I just got back from RRC in Moab, and on the way ...   Sep 18 2014, 10:15 PM
DBCooper   I just got back from RRC in Moab, and on the way ...   Dec 4 2014, 03:38 PM
Amenson   OK, now I'm curious too. Not my car but thi...   Dec 5 2014, 12:17 PM
Chris H.   I had one of my outer (914) CVs do that almost imm...   Sep 18 2014, 06:47 PM
DBCooper   I've broken three CV's (too much fun), all...   Sep 18 2014, 08:31 PM
ruby914   I've broken three CV's (too much fun), al...   Sep 19 2014, 02:53 AM
76-914   I'm having good luck with mine staying on but ...   Sep 19 2014, 08:31 AM
ruby914   I'm having good luck with mine staying on but...   Sep 19 2014, 09:44 AM
ruby914   Parts links: http://rockforddriveline.com/New_Par...   Sep 19 2014, 10:32 AM
76-914   I really need to slow down and read these posts mo...   Sep 19 2014, 05:53 PM
76-914   No help here Paul. I'm running Full Suby inner...   Dec 5 2014, 09:58 AM
rnellums   No help here Paul. I'm running Full Suby inne...   Dec 5 2014, 07:07 PM
- Lo-Fi Version Time is now: 7th October 2026 - 11:27 PM
