FS Replated Silver zinc parts |
bdstone914 |
Sep 14 2014, 10:05 PM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Door strikers. Late type $30 a pair. 3 Pair available
Door latches that go inside the door $75 a pair. 4 pair available Front turn signal bucket clamps $20 per set, 6 available Steel headlight pivots sets. $60, 3 sets set consists of two outer, two inner and four backing plates Late engine blower motor clamps $15 , 2 available late blower clamp for plastic spliter $10. 2 available Lug nut sets of 16, $30 per set, 2 sets available Gas tank charcoal canister straps $20, 4 available Horn mount bracket $10 each 3 available Fuel injection rails and injector clamps. Rails $20 per set. 2 sets available injector clamps 7 sets available $20 per set. $30 for a set of rails and clamps. Attached thumbnail(s) |
bdstone914 |
Sep 14 2014, 10:13 PM
More pictures
02loftsmoor |
Sep 19 2014, 09:22 AM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
bdstone914 |
Sep 19 2014, 06:47 PM
More pictures do you do exchanges? I like pretty shiny things,, like the brake canister strap.. i'm working on my wish list Zinc is not a good choice for plating. It is only good for 400 degrees which the pipes get hotter than that. Most shells are so rusted they will not look good. Better to balst them and spray the shells with high temp paint. |
Lo-Fi Version | Time is now: 1st June 2024 - 04:09 AM |
