> Stock injectors on a 2.1L?, Instead of webers
mtndawg
post Sep 21 2014, 04:39 PM
I recently acquired a car that was originally a 2L and have been told the engine size has been changed to 2.1, which I have not checked yet? The engine currently has webers. Can I use stock d-jet FI if it is 2.1?
Dtjaden
post Sep 21 2014, 06:19 PM
What you can do is use most of the stock d-jet components except the ecu, cold start valve and throttle position sensor and then add an aftermarket ecu, Megasquirt in my case, with a few newer sensors for throttle position and intake air temperature.
This can be done for as little as $500 if you DIY or as much as $2,500 if you have someone do the work for you.
As far as the injectors are concerned the 2 liter d-jet injector flow rate is sufficient to support almost 200 hp.
- Lo-Fi Version Time is now: 1st July 2025 - 09:59 AM
