Exhaust Leaks at head |
NFBrown |
Sep 27 2014, 11:18 AM
Newbie Group: Members Posts: 34 Joined: 27-February 13 From: Boise, Idaho Member No.: 15,587 Region Association: Pacific Northwest |
What is there left to do after filing the end of the heat exchanger pipes, installing new copper gaskets, and torquing to 18 ftlb? I know some say torque untill the leak stops but when pressurized only with the shop vac at least three of the four joints were leaking. But at what torque do the studs pull out?
The car is a 1.7 1973 with 1.8 heads so I used the larger copper gaskets. I'm going to take it apart again. measure the joint to flange dimension, and file the mounting ears if needed. Anybody have any other ideas? Nick |
NFBrown |
Sep 27 2014, 08:17 PM
I removed the heat exchangers again and found that the surfaces that mate with the head are not in the same plane. Probably the result of previous filing. The easy way to correct this would be a milling machine but I'll probably use a file. Then yes, I'll aneal the gaskets. Thanks
Nick |
Lo-Fi Version | Time is now: 13th June 2024 - 06:27 AM |
