Exhaust Leaks at head |
NFBrown |
Sep 27 2014, 11:18 AM
Newbie Group: Members Posts: 34 Joined: 27-February 13 From: Boise, Idaho Member No.: 15,587 Region Association: Pacific Northwest |
What is there left to do after filing the end of the heat exchanger pipes, installing new copper gaskets, and torquing to 18 ftlb? I know some say torque untill the leak stops but when pressurized only with the shop vac at least three of the four joints were leaking. But at what torque do the studs pull out?
The car is a 1.7 1973 with 1.8 heads so I used the larger copper gaskets. I'm going to take it apart again. measure the joint to flange dimension, and file the mounting ears if needed. Anybody have any other ideas? Nick |
messix |
Sep 27 2014, 08:48 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
this is what I have done, loosen all attachments and then lightly tighten the h/e like you are torqueing a cylinder head, little bit at a time in a rotation. then tighten the muffler to h/e.
now while car is still on jack stands start car and listen for exhaust leaks. if you hear it off one of the exhaust ports at the head back off the nuts and tighten again, you might have to tighten down one side of the stub and loosen the other and work it that way to seal it. then work the leaks back to the muffler by tightening and shifting the attachments. watch out for warped h/e to muffler flanges. you might have to hammer them back to straight and flush. |
Lo-Fi Version | Time is now: 13th June 2024 - 04:57 AM |
