> 914-6 conversion question, what else do I need?
Mr_Chu
post Aug 21 2004, 04:53 PM
Ok, so I have a 914 and also a 911SC. I am going to throw in the 3.0-liter motor into my 914.
I have to change the oil tank, I have to do the ring and piston thing, motor mounts, heat exchangers and new oil lines and stuff. What else do I need to do?
I know I have to upgrade suspension and braking, but what else do I need in order to swap motors and tranmission? Do I need to modify anything else? I pretty much have all the pieces to do the conversion, the problem I'm having is actually starting!
Any comments, suggestions, or missing parts I might need to do the full swap?
This conversion is starting to be a nightmare and its also costing me a pretty penny! (IMG:style_emoticons/default/mad.gif) Any help would be greatly appreciated!
Also, thanks for the guys that gave me some pointers earlier. That really helped me out!
joea9146
post Aug 22 2004, 04:20 AM
You will need a clutch adapter kit. You can get it from these guys.
http://www.kennedyeng.com/
You also need a Bell crank kit that bolts to the tranny and allows
the throttle linkage to work, or you will need to Fabricate something.
You will also need 914/6 Sheetmetal kit for the the Engine tin.
That should keep you busy for a while... if you purchase all these item figure about another $1200
(IMG:style_emoticons/default/smash.gif)
Mr_Chu   914-6 conversion question   Aug 21 2004, 04:53 PM
seanery   shift rod. what year is the car?   Aug 21 2004, 05:10 PM
Mr_Chu   It's a 74 914... 2.0-liter.   Aug 21 2004, 08:04 PM
Mr_Chu   I can still use some advice.. <_<   Aug 22 2004, 12:46 AM
McMark   Your question is too broad. Looks like you have a...   Aug 22 2004, 01:08 AM
joea9146   You will need a clutch adapter kit. You can get it...   Aug 22 2004, 04:20 AM
seanery   why the clutch adapter kit? :confused:   Aug 22 2004, 09:28 AM
lylegd   1) The 3.0 liter motor will require use of a speci...   Aug 22 2004, 10:28 AM
!   ring and piston thing.... What's that? The 3...   Aug 22 2004, 10:45 AM
seanery   I still don't get the adapter kit. He has the...   Aug 22 2004, 11:44 AM
!   If he's using the 915 trnas....he needs to fli...   Aug 22 2004, 12:00 PM
seanery   I knew the R/P but 2 people said he needed an adap...   Aug 22 2004, 12:13 PM
McMark   He doesn't need an adapter. The transmission ...   Aug 22 2004, 01:09 PM
Mr_Chu   Hey guys I appreciate the help. First of all I ...   Aug 22 2004, 05:27 PM
McMark
  Aug 22 2004, 09:50 PM
jgiroux67     Aug 22 2004, 11:14 PM
Mr_Chu   thanks guys.. Do any of you guys know a good pla...   Aug 23 2004, 04:35 PM
!   As mentioned before.... GPR.. 800-321-5432 Rich Jo...   Aug 23 2004, 04:45 PM
ArtechnikA   you will also need to have the on-engine oil coole...   Aug 23 2004, 04:49 PM
seanery   Rich Clewett does the oil cooler conversion: Rich ...   Aug 23 2004, 05:22 PM
Cap'n Krusty   Gonna have to figure out a way to mount that 915 t...   Aug 23 2004, 05:36 PM
ArtechnikA     Aug 26 2004, 12:48 PM
Mr_Chu   hah.. well I already bought an engine. Well i ac...   Aug 27 2004, 05:20 PM
ArtechnikA     Aug 27 2004, 06:06 PM
Mr_Chu   ya "one man's junk is another man's treasu...   Aug 28 2004, 10:50 AM
- Lo-Fi Version Time is now: 20th September 2026 - 08:28 PM
