Help: Car won't turn off, ...unless I pull the coil wire |
boxsterfan |
Sep 28 2014, 03:45 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Getting my car back together after replacing the fuel pump with a 2-port Bosch 69133 unit from Napa.
Car starts as normal, but when I turn her off she just keeps running. I can remove the key from ignition and she keeps running. And of course, this isn't some sort of overrun condition....actual running. Pull the coil wire and she dies as expected. Other notes, fuel pump is wired to switch power up front (previous owner did this). :dunno: |
Java2570 |
Sep 29 2014, 01:03 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I think both of my tank fittings are pointing toward pass. side and slightly toward back of the car. In my case, I just used a little too much hose length and there is a limited amount of routing once the tank gets back in. I was surprised how much luck I had checking the hoses for kinks by feel. I'd say be careful to keep your eye on those fuel hoses if you end up going with something not rated for ethanol.
Lo-Fi Version | Time is now: 7th June 2024 - 01:48 AM |
