Fuel pump options for 73 injected model |
maddhatter |
Jul 5 2011, 11:20 AM
Newbie Group: Members Posts: 7 Joined: 5-July 11 From: Clementon, NJ Member No.: 13,279 Region Association: None |
I recently picked up a 73 1.7 that had been stored inside for 20 years. The body is great as expected sitting inside, but the fuel pump does not work among other things and looking for a replacement I see that they are no longer made. Great! Can I retrofit a later model pump to fit my car? I thought the injection systems were pretty much the same all the way through the years, but the newer pumps look vastly different from my hunk of metal pump, mine having 3 hose connections and the newer ones only the typical two. Thanks in advance.
SteveL |
Sep 30 2014, 12:51 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
In the picture above, the pump has been moved to the lower firewall. Can it be left in the stock location on the existing rubber mounts?
If you move it to the firewall, is it loud inside the cabin? Just drill a couple of holes in the firewall for a bracket? Thanks |
Lo-Fi Version | Time is now: 31st May 2024 - 08:34 PM |
