hydraulic cams specific for fi or carb set up?, what cam to use when going hydraulic?? |
funk |
Sep 19 2014, 06:54 PM
Member Group: Members Posts: 100 Joined: 23-June 14 From: sandpoint idaho Member No.: 17,531 Region Association: Pacific Northwest |
I went on the web cam internet site and looked and buying their hydraulic cam set up but it says the cam is build specifically for factory fi systems? is their a cam set up that is for hydraulic lifters and carb set up??
Bleyseng |
Oct 2 2014, 06:53 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
They are a replacement for the valve adjusters in the rocker arms. Instead of a solid tip contacting the valve stem end they are a swiveling piece on a adjuster screw. You have to machine off some of the early 1.7 8mm rocker arm to make it work. This is a nice upgrade as the swivel's flat end then contacts the whole of the valve stem end without any mashing of the valve end. It's slightly quieter too. Combined with chromemoly pushrods and you have a better valve train that doesn't go out of adjustment as fast. Use only Porsche swivel feet ($$$$) as the knockoffs are crap.
Lo-Fi Version | Time is now: 6th June 2024 - 10:03 PM |
